AE85 Brake upgrade
AE85 Brake upgrade
Postby Trls250s » Sat Jun 02, 2007 12:04 am
I wish to upgrade my brakes to something a bit more responsive. Im planning to put a 4age in (which i already have) but i want to make everything else gravy before i do the conversion. Im not planning to make massive numbers but i like the idea of stopping on a dime. Makes canning around the hills a lot more fun too.
Can anyone suggest replacements for the standard 85 ones. Im not looking to get massive after market ones. Just thinking of a upgrade using standard toyota parts, or nissan ones.
I kno cressida, corona GT, carina GT, and AE86 all have 10" vented rotors but are the calipers 2 pot, and is it worth $500 for AE86 parts?!?
Will AW11 Front struts/rotors and all the good bits fit in to the front?
I have considered S13 4 stud 4 pot brakes, i know this can be done with a bit of modification but can someone point me in the right direction?
Cheers,
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Rick » Sat Jun 02, 2007 10:50 am
For a start AE86 dont have 10" rotors or twin pistons, they are single piston and have 243mm (9.5") diameter vented disks.
Your best bang for your buck would be upgrading your pads and fluid of you ae85 brakes.
AE86 brakes come up for sale on TradeMe from time to time and would be your only bolt on brake upgrade option. Any other bakes will need new brackets making and/or mix and matching of parts to make them fit.
AW11 brakes won't bolt up without modification.
Here is some info on adapting S13 brakes to suit a AE85/6
http://www.ae86drivingclub.com.au/forum/index.php?showtopic=7089
Postby l1ttle_d3vil » Sat Jun 02, 2007 11:12 am
Rick wrote:AW11 brakes bolt up without modification.
what stud pattern are these?? and what size brakes?
Postby Rick » Sat Jun 02, 2007 1:10 pm
Sorry I missed the word "won't", AW11's have 4x100 stud pattern, and use front rotors of 258mm diameter.
Postby Mr Revhead » Sat Jun 02, 2007 1:23 pm
whats the use of the car?
to upgrade to ae86 you need the backing plates, calipers and rotors.
all avail new.... but to be honest the calipers are more than youd pay for some better ones
Postby MrDori » Sat Jun 02, 2007 2:18 pm
get cressida, soarer, celica ones.
Just needa a rca to adapt to the 90mm strut bolt spacing, more than enogh stopping for you
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby johntramp » Sat Jun 02, 2007 2:58 pm
audi rotors and nissan 4pots
johntramp
Postby diss7 » Sat Jun 02, 2007 3:46 pm
S14K or R33 brakes.
Makes it 5 stud too.
diss7
Postby Rick » Sat Jun 02, 2007 4:48 pm
MrDori wrote:get cressida, soarer, celica ones.
Thats only half of it, spring pertch needs cutting down, top hat needs replacing with a adjustable AE85/6 one as there is too much neg camber otherwise, also the height of the perch is different to the AE85/6.
Postby rollaholic » Sat Jun 02, 2007 5:37 pm
johntramp wrote:audi rotors and nissan 4pots
something tells me theres more to it than this :P
Postby nzae86 » Sun Jun 03, 2007 10:49 am
The easy way to do it with no cert required
http://www.trademe.co.nz/Browse/Listing ... =102672480
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby Trls250s » Sun Jun 03, 2007 12:57 pm
A lot of feedback quite quickly. Thanks
Just general road use. I like to take my car for a thrash and i wouldnt mind taking it to a track day.
When you own a trueno why not use it.
I think $495 is far to much money for what AE86 brakes and struts are worth for what they are.
I didnt know the rotors were only 9.5" and singple pot. I must have missheard some information when it came to them.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby johntramp » Sun Jun 03, 2007 1:15 pm
re-drill the rotors to 4x80 or whatever it is, bolts in the hub like standard ones and then get a caliper bracket made. dont have to change stud pattern and can still fit a 14" wheel
johntramp
Postby Trls250s » Sun Jun 03, 2007 1:21 pm
Im contimplating doing what the auzzies do and fit S13 assemble to my car. Ive considered this a bit as i use to own a cefiro and did a lot of suspension work on it.
I often gazed under my trueno thinking that that assemble should fit under there. Now ive read that article im seriously contimplating it.
There are S13 brakes and rotors on trademe for $60 and i already own some s13 hubs, LCA. Just need struts and im in buisness.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
