atmosports wrote:I should be able to help you off the top of my head being a Haltech agent but can't as to be honest I've never tried to put an e8 on one of those motors
The ignitor is simply a transistor, the transistor biases at 5v (probably closer to 4.5V actually), because a +12V signal is greater than 4.5V it will still trigger the transistor in your ignitor just fine.
fivebob wrote:It will work, but you have to be able to limit the dwell time to < 1.8ms or it will start to misfire, probably due to overheating.
Also it fires on the rising edge, not the falling edge, so you might find the ECU timing will be inaccurate as the revs rise unless it can be configured for this.
D.3 Falling edge and Rising edge Ignition Modules
The waveform that the ignition module expects can vary depending on which edge the module fires a spark.
Rising Edge Triggered – Some Honda and CDI style ignition modules are known to be rising edge
triggered. These modules expect a 12V input signal when idle. When the voltage falls to 0V, the module
charges the coil. When the voltage returns to 12V, the spark is fired.
AW11 Turbo wrote:well... my english isn't soo good!![]()
a short 12V periode (dwell) for not overheating... is this correct?
in the booklet of my E8 i found this:D.3 Falling edge and Rising edge Ignition Modules
so it lookes like it can be configured!
AW11 Turbo wrote:many thanks for your answers fivebob![]()
i hope my haltech agent is able to configure all in the right way!
but now i have another question for you!
cam- and crankshaft position sensors are both magnetic reluctance types?
do they work with 12v or 5v?
and do you know how to wire them up?
99gtt wrote:If you would like we have an e6x allready tuned and wired up for the caldina 3sgte . It only has mild tune of 250hp at 4 wheels on 14.5 psi . Upgrading the ecu so this is no use and selling for $800 this will solve you allot of time and effort as all the hard work has been done.
