l1ttle_d3vil wrote:5psi - 6psi from engine and ecu is probably the most. pretty sure any more than that and the engine won't handle it for long, and the ecu won't fuel it enough.
standard 4agze ecu with 365cc 4agze injectors will run up to around 15psi though.
Bazda wrote:l1ttle_d3vil wrote:5psi - 6psi from engine and ecu is probably the most. pretty sure any more than that and the engine won't handle it for long, and the ecu won't fuel it enough.
standard 4agze ecu and injectors etc will not fuel it for 15psi.
I did 3 gtz's and we couldnt run any more than 11psi, 12psi was max on the af ratios.
Crampy wrote:My MR2 ran 14-15psi with the supercharger and monster pulley it had on it. Went damn quick, but never checked on dyno or with wideband or anyhting. It still had the top mount interheater too, not good!!!
Crampy wrote:Well, a small turbo is different to a large turbo as well then. I'd bet you're turbo would be a hell of a lot better at compressing air than a tiny little CT9.
Boost pressure is not really what we should be comparing. It comes down to how much power is being made really.
