Error Codes
Error Codes
Postby ee904age » Wed Jun 06, 2007 7:06 pm
Does anyone have a link to the ecu error codes for an ST191 Corona with a 3sfe?
Any help appreciated.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby big_boy » Wed Jun 06, 2007 7:10 pm
1 All OK
2 AFM Vc open Vc / Vc-VS, open Vb AFM Vc/Vs, wiring, ECU
3 AFM Vs open Vs, Vs-E2 short, open Vb AFM Vb/Vc/Vs, wiring, ECU
4 THW THW open Coolant sensor, wiring, ECU
5 O2 Ox stuck rich/lean Oxy sensor, wiring, ECU
6 IG no ignition signal ignition, wiring, ECU
7 TPS Idl/Psw short TPS, wiring, ECU
8 THA open/short intake temperature sensor
9 SPD speed sensor just leave it disconnected -
it's for speed limiter only.
10 STA starter signal
11 A/C air conditioneer switch, TPS or neutral start switch
thats 2S if that helps
for sale EE90
big_boy
Postby ee904age » Wed Jun 06, 2007 7:14 pm
Oops, DUH! check the FAQ....
Cheers big boy
90 SW20 N/A - Sold
ee904age
