fryed an injector? help
Postby EVL20V » Sun Jun 10, 2007 8:39 pm
was removing injectors and a spark occured when the socket touched intake plenum :roll: now sounds like a wrx on 3 $#%#$ cylinders.
resistance across all injectors and plugs the same. reset ecu numerous times. checked all wire/plugs/leads etc.
it blows lots of black smoke also
should i measure the voltage across them? also TPS needs adjusted but shouldnt really be playing a part
EVL20V
Postby RedMist » Sun Jun 10, 2007 10:28 pm
I would have thought it more likely to be an injector driver. The silvertop and I presume blacktop run two drivers for all four injectors. So if your running on two cylinders, then I'd be looking at a new ECU or a repair.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby EVL20V » Sun Jun 10, 2007 10:30 pm
cheers for that .will test with a mates ecu and see
EVL20V
Postby Lloyd » Mon Jun 11, 2007 7:31 pm
Best bet is probably trying your ECU in his car rather than around the other way. If you have a short in your loom or something that blew the ECU then chances are he wont wont you doing the same thing to his.
And blown injector drive would be my first guess on that too
Postby EVL20V » Mon Jun 11, 2007 8:48 pm
oily plug, cleand and fixed now :lol: random
EVL20V
Postby AceSniper » Mon Jun 11, 2007 9:37 pm
:lol: nice
AceSniper
