lowering spring not captive
Postby soven » Mon Jun 11, 2007 6:45 pm
What could cause a spring to not be captive but only on one side?
Celica 98 non-superstrut . Lowered with new toyota shocks and tein springs. Only the front passenger side spring is move-able when the car is jacked up. Clunks sometimes when i turn the steering enough at slow speed(springs unbinding?) and also creaks when I go over a bump etc. All this just on the front passenger side.
Can a damaged top mount cause this? springs were installed twice(once by shop) with old shocks and I took it out to reinstall when I bought new shocks but the problem is still there(torque'd to specs). Just want to know if anyone have an idea of what might be the cause, instead of blindly changing out stuff.
soven
Postby Bling » Mon Jun 11, 2007 7:55 pm
did you use a rattle gun to tighten the tophat down or by hand with power bar? if you didn't use a rattle gun the top nut wont be tight enough.
could easily be something else.... but i'll put money on the above if rattle gun not used.
Postby escortman » Mon Jun 11, 2007 8:52 pm
yeh sounds as tho the top hats loose
4x4 toyota blizzard offroader
escortman
Postby skoty » Tue Jun 12, 2007 7:28 pm
Spring around the right way on the passenger side? Had a similar problem with the spring around the wrong way (mine wern't marked). Caused the spring to move in the top hat as you described while turning and make noises when going over bumbs. Problem was instantly solved afterwards.
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby Loudtoy » Tue Jun 12, 2007 8:08 pm
BZG|Bling wrote:could easily be something else.... but i'll put money on the above if rattle gun not used.
Is it not possible to torque things up to the right torque using a torque wrench rather than a rattle gun. I've done shiteloads of things up with torque wrenches to manufactures specs but never used a rattle gun - should i go and take everything off and do them up only with a rattle gun :wink:
Oh and i'd suggest your spring may well be in upside down or your tophat is stuffed. One option is you have been sold a mismatched set of springs, got one for another car by accident - wouldn't be the 1st time it's happened
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby soven » Tue Jun 12, 2007 8:09 pm
tightened it as much as I could with big socket wrench for now but sound still there. Will jack it up on the weekends and hopefully it is something stupid like installing springs the wrong way :lol:
soven
Postby Bling » Tue Jun 12, 2007 11:00 pm
I'm not knocking using a torque wrench, I also use one. But after installing my springs and shocks by hand, I found it would clunk etc.... took it to a mechanic and got him to tighten them up with rattle gun and it fixed the problem.
A rattle gun can tighten the nut without turning the shock.
problem is, how fast can you turn that torque wrench? a shock will turn when you tighten the top nut when it gets pretty tight.... so unless you are superman, rattle gun ftw
Postby EVL20V » Tue Jun 12, 2007 11:25 pm
ahh yup, u mite need to take another coil off the spring with a makita if u have one handy. then shortn the shocks mate :wink:
EVL20V
Postby Loudtoy » Wed Jun 13, 2007 10:14 pm
Ever spotted the flat part of the shock right near the top where it goes into the tophat and wondered what it was for?? Either that or the top hat (can't say for all but definately the ones i have done) has a key type design that locks into the shock shaft so you can tighten the top hat nut without turning the shock shaft
TS Member sine 2001
Loudtoy
Postby Mike- » Fri Feb 01, 2008 4:29 pm
Loudtoy wrote:Ever spotted the flat part of the shock right near the top where it goes into the tophat and wondered what it was for?? Either that or the top hat (can't say for all but definately the ones i have done) has a key type design that locks into the shock shaft so you can tighten the top hat nut without turning the shock shaft
dont wanna bring up an old topic but what tool do you use for this?
a spanner is way too fat, supercheap and bnt didnt have anything
Mike-
Postby escortman » Fri Feb 01, 2008 5:41 pm
that flat part is what the top hat sits down on2
escortman
Postby Bling » Fri Feb 01, 2008 6:44 pm
Mike- wrote:dont wanna bring up an old topic but what tool do you use for this?
good work using the search, shame more people don't search before asking questions 8)
Postby Mike- » Sat Feb 02, 2008 12:06 pm
ive tried pushing it down but the tophat still spins freely independent of the shock, there must be a way to do it without a rattle gun or vice grips
btw its on a ke70
Mike-
Postby Zak » Sat Feb 02, 2008 12:30 pm
It slots into the top spring perch not the top hat, you want the top hat turning, thats why it has a bearing.
Hold the top perch and try and tighten it, then once it's in the car, tighten it again.
Zak
Postby gmacrae » Sat Feb 02, 2008 5:19 pm
soven wrote:tightened it as much as I could with big socket wrench for now but sound still there. Will jack it up on the weekends and hopefully it is something stupid like installing springs the wrong way :lol:
powerbar/rattle gun, wont make a difference if you know what you're doing. Maybe you have the tophat tightened up but not aligned with the flat spot on the shaft so it hasnt slid down the strut as fat as it should - you get what i mean?
gmacrae
Postby escortman » Sat Feb 02, 2008 7:43 pm
Zak wrote:It slots into the top spring perch not the top hat, you want the top hat turning, thats why it has a bearing.
hahh yeh opps its not the hat its the bit below it
escortman
Users browsing this forum: Bing [Bot] and 7 guests
