Best throttle body suited for a SC14 supercharger conversion
Postby 73corona » Mon Jun 11, 2007 8:16 pm
what i'm doing is i have a 73 toyota corona and have a 20valve converted to rwd in it and i''m mounting a sc14 to it and i need to get a single throttle body to make this work, hopefully using my origanlly 20v 4 pin tps plug. any one help me on this. what would you recommend. bigger is better but i want it to be compatiable. thanks
73corona
Postby slighty_sykotic » Mon Jun 11, 2007 8:18 pm
Um, one thread is enough? Any reason why you don't want to use a 4age one?
slighty_sykotic
Postby Mr Revhead » Mon Jun 11, 2007 8:25 pm
quite.
what are you doing for a manifold?
Postby Zak » Mon Jun 11, 2007 8:50 pm
I have a 3sgte one on mine, same setup as your by the sounds of things
Zak
