16v vs 20v turbo
16v vs 20v turbo
Postby bluemaumau » Fri Jun 15, 2007 8:26 pm
ok im going to start building a new engine.
but havent really found any diffinitive answers on what is easiest/best.
say you had a
16v with 8.9 pistons
and a
20v with 8.9 pistons same setups blah blah
will the 20v have that much more power?
because the way i see it setting up a 20v for turbo is alot harder
20v
more wiring(i think)
custom inlet
more tuning on ITBs
16v
stronger rods
factory inlet
wereas a 16v seems a little easier.
basically is it worth the $&#$% around to get the wank 20v turbo going?
Postby Bazda » Fri Jun 15, 2007 8:45 pm
how much money do you have, thats the question.
its basically up to you to decide, you got the extra cash use the 20v.
the only extra thing you have to do is make a plenum, nothing changes in wiring either.
Postby Calvin » Fri Jun 15, 2007 8:54 pm
If you wanna keep cost down, not much work to be done to your smallport GZE to get it running decent numbers.. and if your not spending to much on it itll last longer imo than the 20v..
Not really a technical opinion but a small insight on my view :)
Calvin
Postby Bazda » Fri Jun 15, 2007 9:29 pm
Calvin wrote:If you wanna keep cost down, not much work to be done to your smallport GZE to get it running decent numbers.. and if your not spending to much on it itll last longer imo than the 20v..
last longer than a 20v, how so?
Postby bluemaumau » Fri Jun 15, 2007 9:33 pm
well theres no rush as im just gona keep building it as funds arrive. next semester is minimal :lol: .
im going to get a silvertop block because i want new pistons and silvertops are dirt cheap..
and gzes ans smallports go for rediculos money!
so im just deciding wether to run the 16v or 20v head.
is any two ppl on the board running the same boost and turbos? on 8.9 pistons in a 16v and 20v?
id rather it doesnt cost a fortune, naturally.
Postby Calvin » Fri Jun 15, 2007 9:40 pm
i always saw the GZE's to be stronger than the weight reducted 20vs (in standard form)
Calvin
Postby Bazda » Fri Jun 15, 2007 9:41 pm
20v head outflows the 16v head in standard form.
so you will always make more power than the 16v in standard form.
Postby ChaosAD » Fri Jun 15, 2007 9:48 pm
16v gze bottem end with 20v head?
ChaosAD
Postby Bazda » Fri Jun 15, 2007 9:59 pm
ChaosAD wrote:16v gze bottem end with 20v head?
I think he is using the 20v bottom end with gze pistons, cheaper to do it that way i suppose.
Postby Mr Revhead » Fri Jun 15, 2007 10:37 pm
a reminder....
cranks, bearings and rods are the same.....
so reliabilty will be the same between the two.
Postby Crucible » Fri Jun 15, 2007 10:45 pm
Mr Revhead wrote:a reminder....
lol the 4a Guru! :D
Crucible
Real Life Mechanic
Postby Mr Revhead » Fri Jun 15, 2007 10:48 pm
im going to get that tattooed on my forehead.... i say it enough :lol:
Postby Crucible » Fri Jun 15, 2007 11:17 pm
A guy in Auckland was building a 4agte with b/t head, how did that go???
I wonder what static comp ratio would be with blacktop head, 8.9 ze bott end, .8 gasket would give? quench??? custom pistons maybe better?
custom tapered plenum,short runners and single Tbody maybe???
Crucible
Real Life Mechanic
Postby Mr Revhead » Sat Jun 16, 2007 9:50 am
now.... some one some where posted up the CCs of the heads......
must.... find.... it....
Postby TRD_ZERO » Sat Jun 16, 2007 10:43 am
True-No-Turbo wrote:A guy in Auckland was building a 4agte with b/t head, how did that go???
Yeah that is the exact setup im building i got all the parts just about to start putting it together, though im using the fatter rods. Id be relly interested what the static comp would be.
TRD_ZERO
Postby flygt4 » Sat Jun 16, 2007 11:12 am
ive got 2 years at over 20psi on a silvertop head 4agte :wink:
flygt4
Postby Mr Revhead » Sat Jun 16, 2007 11:13 am
how mucn running in that 2 years? :P :twisted:
Postby Bazda » Sat Jun 16, 2007 1:31 pm
i've done over 1 year 13,000km, 27psi of boost, drag and circuit!!
20v ftw
Postby Calvin » Sat Jun 16, 2007 1:33 pm
But you guys have built them to be handle that much power.. Im just saying if you were gonna keep it fairly standard my opinion sees the GZE to be stronger.
Calvin
Postby Mr Revhead » Sat Jun 16, 2007 1:43 pm
but standard they are exactly the same as 4age. other than the pistons
if you mean buy an engine slap on a turbo and not open it up. then yes 4agze would be better than a 4age.
but if your talking crank/rod strength etc. then they are the same.
