bluemaumau wrote:did you check the thermostat in hot water?id just go grab a new one there only like 30 buks
big_boy wrote:that fan is nothing to do with the AC & heater its only turns on when water temp is above 97-102`C the AC fan is on the other side of the radatior & heater fan is inside the car
also define normal running thoes fans normaly only turn on in trafic or if something is obstriction radator flow
also check your water pump & that your radator has good flow as these can sometimes affect it
also check your fan belt isent slipping
