ae82 suspension problem
Postby .:O4AGTZ:. » Tue Jun 19, 2007 7:24 pm
well here is th story. there is a nasty knock coming from both front corners when going over bumps. firstly i was told the shock inserts were stuffed, so replaced them...still knocking. The i was told the springs were old and had lost their spring rate or something like that so replaced them too...still there. Any other ideas? one i have heard is strut mounts. or maybe even an engine mount but i have a strong feeling its not that.
.:O4AGTZ:.
Postby soven » Tue Jun 19, 2007 7:38 pm
make sure everything is tightened. Almost sounds similar to my problem where only my left front is making noises when going over bumps and turning. I sort of narrowed it down to top strut mounts.
Are your springs move-able by hand when you jack the car up? What I found with mine is, the problem side is move-able. I suspect that the flat parts of my top strut mount that stops the shock from turning when i tighten the topnut is grinded away therefore I cant tighten it fully. When I try to tighten, it pops and gives me quarter of a turn everytime.
Will report back when I try the rattle gun next week if you still have not sorted it out by then.
soven
Postby Allister S » Thu Jun 21, 2007 6:16 pm
Hey check ALL your engine mount bolts with rachet/spanners - I had an annoying noise that really seemed like suspension but was a mount that looked ok but tightened a bit and it went quiet. Also look at sway bar end links to the lower arms and definitely the strut top mounts as mentioned before.
Cheers, Al
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Users browsing this forum: Google [Bot] and 22 guests
