T50 gearbox recondition
Postby repowered » Tue Jun 19, 2007 8:42 pm
hey
need to get the bearings done on my T50 gearbox. It makes gravelly noises under deceleration (engine braking)
pretty sure its the bearings, a mate can do the job for me, he wants me to source the bearings though. get them through toyota? or anyone else?
Rollin!
repowered
Postby l1ttle_d3vil » Tue Jun 19, 2007 8:46 pm
try saeco. is it a 20 or 22 spline? 22 spline cost a heap more! I can get them for cost thru saeco, and its about $200+ difference between the two boxes when I priced it up.
is it kind of a "knocking" gravelly noise? im thinking it could be a similar problem I had with mine... is it still changing gears sweet? particularly 1st / 2nd?
what type of bellhousing are you using? ae86 or 3a? (if you don't know, what side is the clutch fork on?)
Postby Mr Revhead » Tue Jun 19, 2007 10:18 pm
t50 bearings?
we keep most on the shelf 8)
Postby repowered » Wed Jun 20, 2007 11:33 am
tis a 22 spline, clutch fork is on driver side.
um not really knocking noise more just noisy & gravelly, is a little bit hard to change gears.
my mechnaic freind told me different gearbox oils can make a difference to noise?, was noisy before i replaced gearbox oil but is getting worse, cant remeber grade.
Rollin!
repowered
