mr2 fuel pump!
mr2 fuel pump!
Postby 92mr2paddy » Wed Jun 20, 2007 8:14 pm
ok i have mr2 g limited. with the gen 2 turb motor in it,
it all works great since months now! i am just wondering which fuel pump is bigger (has more flow) the N/A one or the turbo version one or are they both the same model/type of standard pump???
this might be relevant to when i upgrade to ct20b etc etc
thanks pat 8)
92mr2paddy
Postby 92mr2paddy » Thu Jun 21, 2007 6:55 pm
mmmm anyone out there know if there is a difference in the standard fuel pump for an sw20 mr2,, turbo or N/A?? thanks
92mr2paddy
Postby Dell'Orto » Thu Jun 21, 2007 7:00 pm
Nah, basically the same pump.
Postby fivebob » Thu Jun 21, 2007 7:54 pm
Mmm, Boost wrote:Nah, basically the same pump.
Are you sure about this?
I think the 5S-FE powered SW20's in the US have a lower rated pump, not sure about 3S-GE powered ones though.
Postby Dell'Orto » Thu Jun 21, 2007 10:51 pm
Well I'm not so sure about the US spec ones, but I thought the Japanese spec ones were.
Postby tex » Fri Jun 22, 2007 12:19 am
3sge pump is same as 4age etc
3sgte is a same as 7mgte etc
More flow. I have the ND numbers, but can't find the ND book dammit soi can't give you the exact figures.
tex
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
