Link vs Wolf
Link vs Wolf
Postby Emz » Thu Jun 21, 2007 9:43 am
LinkPlus G3 or Wolf V500?
Does anyone have experience with either of these ECUs?
Any comments on the strengths or weaknesses in either of them?
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby big_boy » Thu Jun 21, 2007 11:41 am
Wolf V500 have you found any one that will tune it as i know theres no one in dunedin/chch
for sale EE90
big_boy
Postby Bling » Thu Jun 21, 2007 11:42 am
Links are discussed a lot on here, do some homework by using the forums search function.
Postby AJz » Thu Jun 21, 2007 12:57 pm
links are very easy to setup yourself to an entent. Is there anything specific/features you want an ECU to have ??? With the G3 you can setup antilag, flatshifting, launch control (Only one of).
Lunchie off these forums had a wolf 3d v4/5 (cant member exact) in his levin. Nobody in dunedin would touch the thing. In the end he now had a g3 and works great. But yea, ease of tune with decent features is what id suggest.
Your gonna pay alot less in tuning time if you have an ECU that does the same thing but doesnt require a physics degree to tune (or to that extent. you get my point) Plug in via usb means if you want to play around later on, and you are knowledgeable you can fiddle around with rev limit, idle, rev limit on warm up etc etc.
I had vtax :(
AJz
Postby Emz » Thu Jun 21, 2007 1:32 pm
Ah, thought that might be the case - not many places around to actually tune the wolf.
Emz
Miss Supra Princess
Postby d1 mule » Thu Jun 21, 2007 6:25 pm
how about microtech, that would be my choice if money didnt matter
d1 mule
Postby Burning Angel » Thu Jun 21, 2007 6:32 pm
would definity recommend the link plus g3
very easy to use software which is free(unlike wolf i think)
usb onboard so no interface box needed to connect to a laptop
can do sequential injection and ignition on up to 8 cylinders etc etc
theres really good support for links too. from link themselves and from alot of tuners
Burning Angel
Postby atmosports » Thu Jun 21, 2007 7:22 pm
I'd only use a microtech on a rotary, & even then I'd probably still you use a link/haltech & I sell them all. Microtech is ok, but you are limited with load points & inputs/outputs. Plus it is laptop tuneable but you can't save you maps to disc etc.
As for a wolf, we've tuned a few up here with reasonable results. Noty as fast to tun as a Link but then we probably do 100 times more Links than wolf's. Biggest issue used to be with the triggering & ignition sensor setups on th wolf, but i believe they have solved those now.
atmosports
Postby Lloyd » Thu Jun 21, 2007 7:41 pm
Wolf comes with software and PC cable. New ones look to be a pretty decent step up from the older stuff. Pretty nice looking interface with the PC from the pics too, and seemingly not too bad to tune (as far as the magazine article would lead me to believe).
8 injector outputs (for up to 32 injectors, 16 cylinder), 8 ignition outputs, pretty much anything you want to run it will do, datalogging, 125rpm map steps, internal or external MAP sensor, diagnostics etc
http://www.wolfems.com/content/view/43/
http://www.wolfems.com/component/option ... mode,view/
Just for those who are curious. Doesn't seem bad for the price
