1uz link g3 wiring
1uz link g3 wiring
Postby MrDori » Fri Jun 22, 2007 10:56 pm
hey, im wiring a 1uz up ATM,
It gives us 2 outputs for injector wiring, whats the best way to sort this,
Does the std euc usually fire 4 cly at a time?
Just abit confused on what Order to have the injectors going
cheers anyways
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby QikStarlie » Fri Jun 22, 2007 11:11 pm
they all fire at the same time. so just use the 2 injector drives to split the load
QikStarlie
Postby matt dunn » Fri Jun 22, 2007 11:22 pm
I think the two drive fire 1/2 a cycle out,
but weither way just put 4 injectors up to each output.
There's no point trying to get them in any particular order or sequence as there will always be some firing at open valves and some at closed valves no matter how you do it.
That' the way I wired them up on Dad's GT40 and it runs fine.
Postby QikStarlie » Sat Jun 23, 2007 12:13 am
yeh something like that. its a good idea to stagger them on the rail
QikStarlie
Users browsing this forum: Google [Bot] and 3 guests
