valve clearances on my engine seem fine, so dont think thats whats causing it to be so gutless + foul the plugs. but i've just noticed I can unplug the:
cold start injector
cold start injector sensor/timer
water temp sensor
manifold temp sensor
and none of these effect how the engine runs. I've unplugged them one by one, and also driven the car with all 4 unplugged and it makes no difference at all to how it performs.
do they normally not do much once the engine is warmed up, or is it likely that these sensors are stuffed?
thanks.
