ST205 Cooling System Leak - Help
Postby riddles » Mon Jun 25, 2007 4:28 pm
Ok, so the car is booked in for repairs at the end of the week, but I want to get some idea of what might be wrong and the cost involved so I'm not overly shocked by the bill.
I've searched on here and also googled but can't find a definitive answer.
It is a 1994 ST205 3S-GTE and there is water leaking down the drivers side of the engine between the alternator and timing belt cover. If the car is running then it empties the raduiator in about 1/2 an hour but with the engine switched off it only loses about 750ml. I had a crawl about under the car at the weekend but there was no obvious sign of cracked pipes, it was almost as if it was coming out from under the timing belt cover.
From what I have been able to find I think it may be the the water pump housing but I'm not certain. Any comments and advice would be welcome
riddles
Postby groupagt4 » Mon Jun 25, 2007 5:06 pm
yea i agree with the waterpump housing theory
groupagt4
Postby sergei » Mon Jun 25, 2007 6:13 pm
Most likely would be water pump seal is leaking.
That is same work as cambelt job.
Postby fivebob » Mon Jun 25, 2007 7:51 pm
More likely is the oil cooler water lines, AKA "the hose from hell" to SW20 owners. This is the most common cause of coolant in that area.
Users browsing this forum: Google [Bot] and 2 guests
