celica engine specs
celica engine specs
Postby tech128 » Tue Jun 26, 2007 10:04 pm
hey guys recently purchased a ss3 celica has a
beams 3sge
i was wondering if any one has some info on these engins
power
and ftpnd
comp ratio etc
and maybe some good mods 4 it
tech128
Postby soven » Tue Jun 26, 2007 10:14 pm
coincidentally, if nothing goes wrong..I will end up with one as well this weekend.
VT-i = Variable Valve Timing - intelligent
Inside diameter x process (mm×mm) = 86.0×86.0
Aerodynamic volume displacement (cc) = 1998
Compression ratio = 11:1
The highest output (ps/rpm) = 200/7,000
Largest torque (kg-m/rpm) = 21.0/6,000
all from:
http://beams-redtop.com/
For general celica stuff:http://www.6gc.net/forums
soven
Postby Bling » Tue Jun 26, 2007 10:15 pm
search.php
have a search using the above link. It will provide you will all the information you need if you follow the instructions on the search page and search for what you are after.
