engine mods = what compression?
Postby l1ttle_d3vil » Tue Jun 26, 2007 11:25 pm
if a 20v silvertop is running the internals from an AE101 4agze with a 2mm headgasket, what would the compression on it be?
is there any way to be sure its running the 4agze internals without pulling the engine apart? the engine is in a car and running so need another way of confirming! I'm assuming the above method wouldn't be 100% accurate ...
thanks.
Postby matt dunn » Wed Jun 27, 2007 12:52 am
It is impossible to work out compression ratio from compression pressure.
From my working sheet, ST 20V with AE101 GZE pistons and 2mm Headgasket works out to be 8.56:1 compression ratio.
(asuming ny calculations are correct)
Postby l1ttle_d3vil » Wed Jun 27, 2007 9:18 am
damn thats pretty low...its only running small boost.
I wasn't really wanting the c/r though. I've seen people before say "if its got xxx pistons, do a compression test and it should be around xxxpsi"
I'm wanting to know what the compression pressure will be if it is running these pistons. otherwise i'm just taking someones word that its got mean strong pistons in the engine!
Postby Mr Revhead » Wed Jun 27, 2007 12:18 pm
ring around some workshops (i suggest ones involved in racing) and see if they have an endoscope. that is a device that you can inspect the chamber. then you will be able to look at the top of the pistons.
Postby l1ttle_d3vil » Wed Jun 27, 2007 6:28 pm
probably don't have any workshops around here with a tool that flash :lol:
but if I can get hold of one, what would I be looking for to identify the ae101 gze pistons?
Postby bluemaumau » Wed Jun 27, 2007 6:32 pm
i gues the 4agze pistons will only have four valve cutouts (altho ive never seen them in person)
Postby l1ttle_d3vil » Wed Jun 27, 2007 7:11 pm
uh, yeah...ofcourse :oops: I knew that! :roll:
Postby Dell'Orto » Wed Jun 27, 2007 7:17 pm
l1ttle_d3vil wrote:damn thats pretty low...its only running small boost.
8.5 isnt that low, Gen 3 3SGTE's are that. Try a dirty ol YB at 7:1 :lol: Or 930 Porsche with something idiotic like 6.5:1
Postby matt dunn » Wed Jun 27, 2007 7:57 pm
bluemaumau wrote:i gues the 4agze pistons will only have four valve cutouts (altho ive never seen them in person)
Yes the AE101 GZE's will only have 4 cut out's
but so will AE92 GTZ
and AW11 GZE one's.
You need to know what your looking at.
Matt
Postby bluemaumau » Wed Jun 27, 2007 7:58 pm
at least youll know its running gze pistons rather than 20v tho!
unless its got N/A 16v pistons in it 8O :lol:
Postby TRD_ZERO » Wed Jun 27, 2007 8:17 pm
and AW11 GZE one's.
Matt
Then what do those super dished ones come out of?? Seen them on trademe once doesnt look anything like my ae101 gtz ones and they guy said he pulled it out of his ae92 gtz.
TRD_ZERO
Postby bluemaumau » Wed Jun 27, 2007 11:43 pm
i think the dished ones are ae92
dish
Postby ezy10s » Wed Jun 27, 2007 11:58 pm
more likely to be aw11 8.0-1 pistons than ae92 8.9-1 items,
as for finding out if it actually has what the seller is saying- youll just have to ask him a whole lot of questions like who installed them, re they over sized, what block is used, what else was done while it was apart, receipts? etc and try make an educated guess whether he is on the level or not.
Member #244
ezy10s
Postby bluemaumau » Wed Jun 27, 2007 11:59 pm
i meant the 8.0-1 ae92 ones
my bad
