Weighing conrods
Weighing conrods
Postby KinLoud » Fri Jun 29, 2007 7:07 pm
OK - I know HOW to weight them using accurate scales....
I plan to put 4age rod weights up in the tech FAQ about 4age rods.
BUT - when rods are weighed what do you include? I need an industry standard please...
- rods (well doh!)
- caps (most likely)
- bolts (maybe, maybe not... factory or aftermarket?)
- nuts (see above)
- bearing shells? (I guess not)
- gudgeon pins (separate weight for interests sake?)
PLEASE - DON'T POST UNLESS YOU KNOW THE ANSWERS PLEASE!
None of the "my cousin's dog's half sister's vet's mechanic said..." replies please
Thanks
Ken
Ham
021 408 863
Postby 85AW20v » Fri Jun 29, 2007 10:06 pm
I wouldn't really think it matters what you include Ken as long as you specify what your baseline is - and use that for all the different types you're weighing. I would think it would be the bare rod with endcaps bolted on - no bearings, gudgeons or shells.
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Fri Jun 29, 2007 10:08 pm
Simon85MR220v wrote:I wouldn't really think it matters what you include Ken as long as you specify what your baseline is - and use that for all the different types you're weighing. I would think it would be the bare rod with endcaps bolted on - no bearings, gudgeons or shells.
But possibly also without rod bolts and nuts, as aftermarket conrods usually specify weight, and then give an option on different size bolts.
Postby Grrrrrrr! » Fri Jun 29, 2007 10:25 pm
rods and endcaps without bolts/nuts.
then specify weight of standard bolts/nuts. and ARP, and if you really feel like going overboard then pins too :)
+10 Karma to Kinloud for putting useful info in Tech Section :)
Grrrrrrr!
Postby AceSniper » Sat Jun 30, 2007 1:46 pm
Rod, cap and state the added weight for stock, and arp's
Or list the rod weight 3 times, no bolt, stock, arp's... depends how much time you have
Weigh pins serprate for intrest sake :) I notice blacktop ones are shorter and have less meat inside over silvertop so weights should very abit, Also wouldnt mind seeing piston weight's without rings.. (dono if it should include keepers?)
eg Silvertop piston ***grams pin ** grams
I have a range of pins, pistons and bolts if you need
AceSniper
Postby AceSniper » Sat Jun 30, 2007 2:28 pm
http://www.junauto.co.jp/products/cylin ... ex.html?en
there is a chart of the Jun rod spec's for an example, 4age one is 422grams
http://www.club4ag.com/faq%20and%20tech ... 20ROD.html
Also some weights on there for an example incl TRD(Carrillo) rods
AceSniper
Postby KinLoud » Sat Jun 30, 2007 3:31 pm
Thanks guys - will post it when I get all the bits together
Ken
