Gear Selectors
Gear Selectors
Postby Caribeena » Sun Jul 01, 2007 10:56 pm
hey guys, just changed the clutch in my glanza v, everything is sweet apart from now when i select either 5th or reverse and then take it out of gear (not moving car is stationary) it wont return properly.... it stays over to the right and has to be given a nudge to return to its central position.
has this happened to anyone else before?
or anyone know why this could be?
Caribeena
Postby AceSniper » Sun Jul 01, 2007 11:22 pm
cable is sticking/cought up?
just a guess
AceSniper
Postby Mr Revhead » Sun Jul 01, 2007 11:49 pm
or possibly youv knocked the selectors a bit, maybe bent them.
have some one sit in the car and work the lever while you have a good look, maybe you can see whats out of place.
when i converted my cousins ae101 to manual the selectors got a knock, so it did weird stuff like only have 3rd and 5th or something :lol:
Postby 79rolla » Mon Jul 02, 2007 8:57 pm
my brothers bluebird does that
push it to the right and gear stick will just sit there and you have to push it a lil bit to go back to center
past: AE82 FXGT
79rolla
Postby thaphatty » Mon Jul 02, 2007 9:08 pm
my guess would be when re installing you've routed the gear shift linkage cable slightly different to its stock location. extra/sharper bend etc = friction
thaphatty
Postby Emperor » Mon Jul 02, 2007 9:21 pm
My RX7 did that, with the MX5 gearbox.. Didn't think much of it, till 6 rounds into the series, and it wouldnt select 3rd, turned out the fork at bent, and then snapped after awhile.
Emperor
