BZG|Bling wrote:Cranks are all the same amount 4ages so will be fine to fit the 20v crank in.
I think the blocks are the same too, so you should be able to fit whichever bluetop parts in you wish. Probably best to just swap the pistons tho (20v pistons wouldn't go well with 16v head) and keep the less km internals of the silvertop in place.
thats from what i've read anyways, someone will have done it and will post
3T-Rona wrote:also when setting the dizzy timing do i need to jump any of the pins in the diagnostic port, if so which ones would they be at the ecu as the diagnostic wiring is gone........ cue spooky music :d cheers all
3T-Rona wrote:Whats the deal with TVIS? whoever put the motor in had it fixed open so i just removed the sandwhich plate altogether, as i havent had much 4age driving experience how does this change the way the engine acts?
l1ttle_d3vil wrote:
you referring to the black diagnostics box? if its a genuine rwd loom it probably wont have one, all old rwd 4age looms i've seen have a yellow 2 wire plug which is the diagnostics plug. it will have a brown wire and a blue/white wire iirc, just short the two terminals on that plug and its in diagnostics mode. the plug will be over by the dizzy end of the loom.
matt dunn wrote:...and they are just as the loom comes out from the firewall, near the wiper motor and a/c pipes, not near the dist.
KinLoud wrote:When you short the plug to do the timing make VERY sure that the throttle if fully closed - the throttle position switch/sensor will detect even a small opening of the throttle and make it impossible to set the timing correctly (been there, done that!)
Ken
Ham
021 408 863
