4age ae92 auto problem
Postby aaron » Wed Jul 04, 2007 1:07 pm
The problem I have with my auto ae92 levin is that the car when traveling at low and moderate speeds under no load it pulses between gears, this goes away as soon as you give it a little gas but is still annoying. if anyone could point me in the right direction towards fixing this would be great.
Owned cars:
4age powered 1973 ke25 corolla
4k powered 1974 ke25
AE101 20v trueno
AE92 Levin
http://toyspeed.blakjak.net/profiles/profile.php?id=68
aaron
Postby themaleman » Wed Jul 04, 2007 4:45 pm
i dont know if its the gearbox, but if u need a new 1 i have what your after 8)
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby aaron » Thu Jul 05, 2007 11:26 am
Anyone have any idea, transmition problem, computer on some sensor that relays information to the computer. I dont want to change the transmition if I dont have to.
Owned cars:
AE101 20v trueno
AE92 Levin
aaron
Postby sergei » Thu Jul 05, 2007 11:39 am
Check the freeplay in the kick down cable. There should be some slack in it.
Also check if the cable is inserted in the gearbox properly (it can come out loose and pull on itself all the time. Disconect temporary the kick down cable, try to push/pull it with your hand and see if it goes in and comes out smoothly. Take it for a drive with cable off and see how it behaves.
Postby aaron » Thu Jul 05, 2007 2:06 pm
cheers I will Try that
Owned cars:
AE101 20v trueno
AE92 Levin
aaron
