1) what options do I have for bellhousings when it comes to fitting an ae92 4agze flywheel (224mm) inside? it doesn't matter what gearbox the bellhousing bolts to...
2) is the ae92 4agze flywheel idential to the aw11 4agze flywheel?
i know they won't fit inside the 4a - t50 bellhousing but what about other bellhousings like the fwd 16v bluetop, redtop etc? will a 4agze flywheel fit inside them or are they identical (within reason ofcourse!) to the 4a - t50 bellhousings?
i'm guessing the k50 bellhousing would be far too small for a 4agze flywheel?
or is the problem to do with the clutch plate etc fitting instead of the actual flywheel itself?
thanks.
