After filling up with gas today car started intermittently missing and loosing power, straight away after leaving pump for 5 sec then nothing for 5min then another 2-3 sec whilst boost'n up .
By this time i'd noticed that the lack of power was acompanied by the A/F gauge going full lean and was heading home.
It then started doing this at the lights, rpm drop a/f goes full lean car barely runs but cleared as i pulled away.
Came back with vengeance on its mind and stranded me on side of road, car still ran but with no proper fueling i wasn't going no where.
Checked all wiring i could get to, ballast, firewall grommets, fuses etc nothing appeared damaged or loose.
Engine is 3S-GTE, Link LEM V1, 2 banks of 4 injectors(4 rolla,4 3S)
What should i check first? I cant easily access the injectors without pulling half the car apart.
could it be water in the fuel? right after filling up, water sinks in petrol right?
