Effects of heavy driveline componets with a n/a 4age?
Postby Zak » Sun Jul 08, 2007 9:46 pm
I was thinking of making a few changes to my car, one was putting the quads back on my silvertop and running n/a for a while.
What kind of effect would the heavy 4agze fly wheel W58 and Hilux rear end have on the performance.
As far as I'm aware the standard ae86 stuff isn't really all that strong to start with, so the pro's would out do the cons?
I do have a T50 and T series rear end that I could put in, but would it be worth it? Considering I'd probably just break it.
Zak
Postby Dell'Orto » Sun Jul 08, 2007 10:13 pm
Why would you do that???? With all the heavy forced induction bits, it wont be as revvy as if it were fitted with the lighter flywheel and other reciproating bits, but it'll be fine.
Would be gutless as hell compared to what it is currently though! You'll really miss the low end torque.
Postby ChaosAD » Sun Jul 08, 2007 10:23 pm
Especially with the lowered compression
ChaosAD
Postby rollaholic » Sun Jul 08, 2007 11:45 pm
i remember when i broke the SC belt on my last 4AGZE, man that was some serious nana mobile shit.
Postby Zak » Mon Jul 09, 2007 8:09 pm
Remember that the engine currently in my car is a standard silver top, 10.5:1 compression and all. So thats not a problem. The car just doesn't feel quite right with so much power, I never get a chance to open it up caus it goes to fast to quickly :(
I would like to do the turbo conversion at some stage, but I want to do it properly rather than just half ass it and cook the engine.
Zak
Postby rollaholic » Mon Jul 09, 2007 8:28 pm
the SC is too fast but you want to go turbo? O.o
Postby Zak » Mon Jul 09, 2007 8:41 pm
Yup, on a turbo, you can have a boost controller, on the supercharger, it's on or off and if I want any thing else, gotta change the pully :x
Zak
Postby matt dunn » Mon Jul 09, 2007 9:06 pm
Zak wrote:Yup, on a turbo, you can have a boost controller, on the supercharger, it's on or off and if I want any thing else, gotta change the pully :x
do you realise that the minimum boost on a turbo setup will still be more powerful that the s/c setup.
Postby Zak » Mon Jul 09, 2007 9:44 pm
Yup, but it will be alot smoother, and nicer to drive.
Zak
Postby IH8TEC » Mon Jul 09, 2007 10:02 pm
my car, same dyno both times, s/c on 12.5psi = 101kw atw, small t3 on 10psi got 125kw atw.
Postby EVLGTZ » Mon Jul 09, 2007 10:16 pm
same for mine 10psi s/c 91kw, 10psi turbo 131kw...same dyno
But get what you are saying zak re driveability. With turbo you can drive it n/a styles without putting the turbo into work, however with s/c it comes on straight away
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Mr Revhead » Mon Jul 09, 2007 10:36 pm
maybe you should go n/a if your worried about having too much power :?
nothing at all wrong with the drivibility of a s/c 4age.... i hardly think slapping a turbo on it will make it any easier to drive. infact itll be harder if its got more power.
i sersiouly think if you go turbo itll be worse than now.
however your "worse" is exactly what most others are after!! :lol:
Postby Zak » Mon Jul 09, 2007 10:37 pm
EVLGTZ wrote:But get what you are saying zak re driveability. With turbo you can drive it n/a styles without putting the turbo into work, however with s/c it comes on straight away
Thats it, if any of you went for a ride in my car, and how loud it is on boost, and backing off, I think you'd agree converting it would make a very big difference.
Not after any more power what so ever, just drivability.
Zak
Postby EVLGTZ » Tue Jul 10, 2007 12:46 am
err thats whats i said mate.....i was agreeing with you
and have actually been in your car before it was yours
EVLGTZ
EVLGTZ
Postby mjrstar » Wed Jul 11, 2007 2:06 pm
Zak wrote: The car just doesn't feel quite right with so much power, I never get a chance to open it up caus it goes to fast to quickly :(
I would like to do the turbo conversion at some stage, but I want to do it properly rather than just half buttocks it and cook the engine.
hmm i have just uprated the turbo on my kp 60... 190kw atw wasn't enough..
anyway if you are going to turbo i'd rate the w58/hilux combo as it's what i gave behind the 1g.
If you are going to keep it s/c stick with the current setup as i'd say the hilux would sap a bit of power due to the reciprocating mass..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby rollaholic » Wed Jul 11, 2007 6:42 pm
i'm pretty sure his cars already got the hilux / W58 setup in it, hes asking if he should put the lighter stuff back in as hes thinking about taking the SC off for a while.
Postby Zak » Wed Jul 11, 2007 8:35 pm
EVLGTZ wrote:err thats whats i said mate.....i was agreeing with you
Sorry mate, came out a bit wrong. Didn't intend to sound like a d**k :oops:
Was my car at the same stage it is now or one of the older engine setups?
Zak
Postby RS13 » Wed Jul 11, 2007 9:54 pm
Pretty sure Skewes had a hilux rear and W58 in his 4age DX, seemed to go alright.
RS13
Postby MR2SIK » Thu Jul 12, 2007 12:59 am
can you not have the s/c on a switch? stop the relay from engaging the clutch, flick the switch for when you want the power?
or get on of them rpm based switches set it to 5000rpm and call it vtak :lol: probably wouldnt help the drivability issue though lol.
I noticed the difference of a lightened flywheel in my old 4agze, can only imagine how noticable heavier gear would be on the 4age..
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Mr Revhead » Thu Jul 12, 2007 9:41 am
yes i would think a switch would be a better idea.
then you can drive it as a n/a 20v when you dont want the power
