by Pirken » Sun Aug 05, 2007 2:44 am
I order the AEM F/IC and i wonder a couple of things .
My crank shaft position sensor and the cam position sensor have the same Ground, is this a problem ?
I just put the to ground together to the minus signal from crank/cam.
The Maf sensor should this be put on the Intake air temp or the Intake manifold temperature ?
or do the 3.5 gen 3sgte have a maf sensor ? or only Map sensor. if Map sensor should i use the output from the manifold pressure instead ?
And i can seem to find a signal ground on my pin list. i just grounded it to a ground signal from ecu.
I haven't mounted the o2 sensor yet because cant seem to find the type of resistor in any store here.
The engine starts just fine , but when reaching 3500 rpm it halts the ignition. but this it just fine before the mapping or ?
Have a LHD Caldina 1999. And i love it !!
