AE86 LSD Question..
AE86 LSD Question..
Postby HachirokuGTV » Tue Jul 10, 2007 12:13 am
Is it true that in order to fit an lsd head to non lsd axles that you have to shorten the axles to make it all fit??
Diff in question is a Kouki AE86 (facelift).
HachirokuGTV
Postby Rob_GTZ » Sat Jul 14, 2007 8:27 pm
Depends on the brand of the LSD, The TRD model is fine with non LSD axles, however on some other aftermarket brands of LSD shortening is required
Rob_GTZ
Postby HachirokuGTV » Sun Jul 15, 2007 9:36 am
What ive since found out is that any aftermarket lsd will fit and that it is only the factory lsd that you need to shorten your axles for.
I now have a new 2way cusco lsd on the way from Switzerland. Crazy that its cheaper to get one from there than it is from here.
I guess Mazsport aren't as interested in Toyotas as Mazdas. Which makes sense only they are a Cusco dealer so........................wtf?
HachirokuGTV
Postby rollaholic » Sun Jul 15, 2007 11:56 am
out of interest, what did you pay for the cusco unit?
i understand they have a machined housing and as a result are bigger than the TRD item?
Postby HachirokuGTV » Sun Jul 15, 2007 3:00 pm
Cusco have more plates than trd's also. Somewhere around a grand.
HachirokuGTV
Postby Dunny » Mon Jul 16, 2007 12:22 pm
rollaholic wrote:out of interest, what did you pay for the cusco unit?
Some would say that KAAZ and Cusco are superior to TRD, no hard evidence just peoples opinion I guess
Dunny
