avinesh wrote:does the soarer need a different fuel cut defender from other toyotas or do they all use the same one
gmacrae wrote:avinesh wrote:does the soarer need a different fuel cut defender from other toyotas or do they all use the same one
If you use a greddy bcc for the jza80 it will work sweet, you just have to tune the voltage clamp to whatever is right for your car - was 4.35v in my surpa.
Silent Knight wrote:I'm using a Gizzmo FCD.
Doesn't need any settings etc. just wire it in (3 wires from memory) and she's all go.
postfach wrote:I don't see how any FCD type device could be described as "ok", they allow you to run more boost without injecting more fuel, which is a sure-fire way to cook your engine. IMO a better use of the money would be to find a way to limit the boost (which is pretty easy, just add more backpressure to the exhaust in most cases) or save up for an aftermarket ECU which will allow you to run the higher boost safely. But hey, that's just me.
