name those wires?
name those wires?
Postby EVL20V » Sun Jul 15, 2007 5:43 pm
ok on 20v ae101,
theres 8? wires running down side of cam cover, since i have removed a/c i have 6 wires doing nothing.
1 wire = plug beside oil filter
1 wire = vvt solenoid wire
am left with 6 wires, 1 would have been air temp sensor, 1 or 2 for the A/C unit? also anyone fixed the issue with fan running with key turned to IGN? :lol: cheers
EVL20V
Postby neo » Sun Jul 15, 2007 6:40 pm
ahh the fan running 100% after removing the air con..
Split open the loom the water temp switch (one on the thermostat) goes into and join its wire to the other one with the same colour codes.
neo
Postby themaleman » Sun Jul 15, 2007 6:50 pm
ohh so thats why my fan always comes on on ign hahahaha, thanks
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby 85AW20v » Sun Jul 15, 2007 9:30 pm
Oxy sensor wires run across and down that way - I think......
See ya
Simon
85 MR2 20v
85AW20v
See ya
Simon
85 MR2 20v
85AW20v
Postby KE25-KP30 » Sun Jul 15, 2007 10:53 pm
Could that also be why my fan runs all the time? Because the air con has been pulled out?? ('86 EP71 Turbo S)
KE25-KP30
Postby EVL20V » Sun Jul 15, 2007 11:14 pm
hmm, would the car even run with no oxy sensor wired up? :lol:
so its an easy 1-wire fix to stop fan running. cheers
EVL20V
Postby neo » Mon Jul 16, 2007 12:29 am
yeah the car will run without the oxy sensor..
Umm The oxy sensor wires (4 of em) would be in the rear half of the engine loom, I just spliced the front half, trying to trace the wires untill I tried this and it worked :lol:
neo
