Engine light in 98 Celica St202 3sfe
Postby Charged1 » Mon Jul 16, 2007 4:26 pm
Hello what could be the possible cause of the engine light coming on , It takes about 5 mins then comes on then goes off after about ten minutes and stays off untill car is started up again then away it goes again ? Thanks
Charged1
Postby barryogen » Mon Jul 16, 2007 4:49 pm
could be one of many things, probably best to either read the codes of it, or have someone do it for you.
to me it sounds like oil pressure maybe, as in it takes too long to get up to pressure, and is then fine... either way, I wouldn't be driving it until you know whats borked.
barryogen
2ZZ Guru in training
Postby Mr Revhead » Mon Jul 16, 2007 6:09 pm
check codes..... have a search on how too its all over here.
could be just about anything
