mk3 supra manual conversion - spigot bearing
Postby tractionfree » Mon Jul 16, 2007 5:27 pm
hi all, i'm in the middle of a manual conversion on a 1ggte supra, got all the slushbox stuff off and out, and now i go to put the spigot bearing in and it wont fit. have i been given the wrong one or is there already one in there that needs to be removed? (if its anything like the skyline ones, aaaaaaaaagh). cheers
tractionfree
Postby Ae92typeX » Mon Jul 16, 2007 8:10 pm
its not a sloppy fit (needs to be carefully knocked in), but if its clearly a different size you may have been given the wrong one. From memory there shouldnt be anything there. wasnt when I did the conversion.
Several people on here have dont it, so someone else should be able to confirm.
Ae92typeX
Postby tractionfree » Mon Jul 16, 2007 8:14 pm
yeah if i look into where the spigot goes, theres a line running around the inside about 10mm in, almost like there is an auto spigot bush there a la skylines (the only other car ive really had a lot of manual conversion experience with). but if you reckon the bearing is supposed to go right in, and cant remember having to pull the bush out, then its probably supposed to look like that.
depends what you mean by knocking in.. yeah pretty sure i could persuade it in there but not too sure how healthy itd be for the bearing. its probably 1-2mm oversize?
if it makes any difference this is an 86 supra
tractionfree
Postby tractionfree » Mon Jul 16, 2007 8:18 pm
actually while im on the topic i might as well add these questions too;
i dont have a manual driveshaft from a 1ggte supra, but i do have one from a 7mgte supra.. if i swap the drive yoke over, will this be the right length? (it is slightly longer than the auto 1g shaft)
while everything is off is it worth replacing the rear oil seal.... do supras have problems with these? not that interested in making more work for myself but considerably less interested in pulling this box again if oil gets into the clutch.... cheers
tractionfree
Postby Ae92typeX » Mon Jul 16, 2007 8:27 pm
From memory (so wait for other replies) spigot bearing sits almost flush-just after the taper. by knock inI just mean tap in with a small hammer and a socket the same o/d as the bearing outer shell. if its 2mm bigger I would question it being the correct one.
I had a custom shaft made, so unsure re:7m shaft length. It is slightly longer though.
Assuming you have sorted the box mount & already bridged the auto inhibitor. You can take the auto ecu out then also.
I'd replace the rear seal while its open - its not difficult & worth it if engine has done a bit of mileage.
Ae92typeX
Postby tractionfree » Mon Jul 16, 2007 8:31 pm
Ae92typeX wrote:From memory (so wait for other replies) spigot bearing sits almost flush-just after the taper. by knock inI just mean tap in with a small hammer and a socket the same o/d as the bearing outer shell. if its 2mm bigger I would question it being the correct one.
we have factory 5 speed gbox mount. i hear that i may still have to drill some holes?
the car already starts in any gear so im guessing the inhibitor has taken care of itself :P how much for a rear seal? cheers
tractionfree
Postby Ae92typeX » Mon Jul 16, 2007 8:35 pm
on the factory mount you will only line up 2 of the 4 box bolts. Some just do that. I welded on longer tabsto make all 4 bolt up. Technically a modification, but it looked origonal and was just as strond as.
email revhead for seal price. not too expensive, but I have forgotten exact price.
looks like I was wrong re:spigot bearing position:
http://www.conceptual.net.au/~peewee/gbox_conv_1.html
Ae92typeX
Postby tractionfree » Mon Jul 16, 2007 8:35 pm
the 1-2mm oversize is before taking the taper into account so im guessing it'd be even more oversized. should probably pop into repco and have a looksee
tractionfree
Postby tractionfree » Mon Jul 16, 2007 8:38 pm
ive used the flexplate bolts for the flywheel, been told that thats ok as long as long as its not going to be put under extreme pressure, sound right?
tractionfree
Postby Ae92typeX » Mon Jul 16, 2007 8:45 pm
they are about 6mm shorter arnt they?
Up to you, but if it was my legs I'd go buy the correct length & make sure are torqued to specification.
Silent Knight or Quint may have more input also, they have both done the conversion also.
Ae92typeX
Postby tractionfree » Mon Jul 16, 2007 8:46 pm
Ae92typeX wrote:they are about 6mm shorter arnt they?
sweet well i'll wait till they show up and i'll bug them for answers. definatley sounds like ive got the wrong spigot bearing here though
tractionfree
Postby Quint » Mon Jul 16, 2007 9:23 pm
Didnt read the replies too well but.
Spigot bearing needs to bit nicely snug, knock it in with a piece of wood over the bearing so you don't $&#$% it, also add some grease around the outside of the bearing so when/if you want to take it out to replace it, its not fused on there.
As for the x member (i think thats what u asked, again i skimmed it... so lasy) You may need to make up a bracket. These were mine:
Real easy and simple, can't tell the differance when ur looking up, just ha three bolts instead of two.
Also replace your gearbox input seal, i didn't the first time and i ruined a clutch because of it.
Quint
Postby tex » Mon Jul 16, 2007 10:03 pm
I personally would not be using flexi plate bolts for the flywheel....... Pretty sure they are quiet a bit shorter.
As for the bush it should just push in like in the nissans. If it doesn't when it has been soaked in oil etc then it probably the wrong size. You don't have that problem with nissans. One bush fits all. Getting the auto bush off is the hard part :)
tex
Postby tractionfree » Mon Jul 16, 2007 10:07 pm
tex wrote:Getting the auto bush off is the hard part :)
oh mate is it ever. we tried everything. internal bearing puller, the soap/grease trick, ended up grinding through it with a mounted stone and pulling it out with vicegrips
tractionfree
conversion
Postby docTRD » Mon Jul 16, 2007 11:02 pm
hey man howsit its james here from repco today yea hows the conversion goin? when i did myn on my chaser it was relatively straight forward ay . pulled off the flexiplate and stuff then got a new spigot bearing and tapped it in with a socket on top, went in fine and i think it did stick out about 1-2mm . ther wasnt any other thing to pull out when it was auto so was easy. il get u the part number for the spigot bearing. and as for the flexiplate bolts i wouldnt reccomend using as yea they are alot shorter. luckily when i did my conversion i had a flywheel and bolts from another 1g motor. see how ya go.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Re: conversion
Postby tractionfree » Mon Jul 16, 2007 11:24 pm
docTRD wrote:hey man howsit its james here from repco today yea hows the conversion goin? when i did myn on my chaser it was relatively straight forward ay . pulled off the flexiplate and stuff then got a new spigot bearing and tapped it in with a socket on top, went in fine and i think it did stick out about 1-2mm . ther wasnt any other thing to pull out when it was auto so was easy. il get u the part number for the spigot bearing. and as for the flexiplate bolts i wouldnt reccomend using as yea they are alot shorter. luckily when i did my conversion i had a flywheel and bolts from another 1g motor. see how ya go.
hey dude yeah was trying to remember your login on here but couldnt. pretty sure this bearing is too big. it wouldnt fit the machined section let alone the inner bit. unless i can find someone with the bolts i might just go to the bolts and fasteners place on te rapa straight and ask for '6 of these but 6mm longer'. probably better than using someone elses second hand flywheel bolts anyway.
want to price me up that rear seal and spigot bearing? cheers
tractionfree
Postby blackmk3 » Tue Jul 17, 2007 9:12 am
Just go to toyota and buy 6 genewin manual flywheel bolts, thats what i did there like $3 each and cheap insurance compared to your flywheel letting go at 7000rpms
Also for the spigot once again go to toyota, not sure on the price but its bugger all, fits straight in and lasts 200,000kms +
Much better than a repco part if you ask me, when i did my conversion it was straight forward and quick
Mk3 MA70 Supra
blackmk3
bits
Postby docTRD » Tue Jul 17, 2007 7:01 pm
hey man yea i got the part number from repco of the spigot bearing i used, its a 1196001 NTN bearing. fit perfect pretty much. theyre about $7. the rear seal i havnt priced up but can prolly get it to u for about $15? . see how u go man. cheers
docTRD
Mo Joe
Postby tractionfree » Tue Jul 17, 2007 7:25 pm
sweet as dude. probably swing by tomorrow and grab it if youve got it in stock. you got the spigot bearing there too? cheers
tractionfree
Users browsing this forum: Google [Bot] and 19 guests
