Tukumi wrote:Hey, two main things that will cause the boost to spike on your setup.
1 is the wastegate hold value. To setup the boost control for the road set the wastegate hold value to 1 then test the boost control in the gear that it is giving you trouble in, if it still spikes then its more than likely the wastegate base number, from memory yours was set on 50, this may need to be more like 45. You basically need to adjust the base number up or down until the boost comes on to within a psi or so then the closed loop boost control will take over from there. Once you have that right you can bring the wastegate hold number back up untill it starts to spike then back it off slightly.
If you have any trouble let me know and i could give you a call.
Hows it going apart from that?
Cheers Phil
NZEFI
Cheers Phil, will go have a tinker and report back, Its going great
completly exceeded my expectations. It just hits so much harder than before, found myself in a few licence losing situations on the way home
And yea, I have a Gizzmo ebc, but It broke. Launching on a track just after 2 jet cars have gone down it provides a fair bit more grip, resulting in said controller flying out of the dash and ripping the connections in the process
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
