Got my 98 celica with superstrut checked out at toyota due to play on the right hand front. Diagnosed as ("lower suspension arm worn at joints") Got told that I should replace both the figure8 and the camber control arm at the same time because it seems that if one is gone, the other would most likely have to be replaced too.
What are your experiences? The joint that was indicated as having play was the joint between lower arm and figure of 8. Would it be bad if I replaced for example the lower arm first and see if it solves the problem or would it cause damage to the new part.
Bloody expensive stuff, Revhead I need your help
