ST185 Radiator fan staying on all the time
Postby ALLTREC_TURB » Thu Jul 19, 2007 4:50 pm
My car is finally running now but the radiator fan is running all the time, have tried two different thermostats on it with no change, the air-con has been removed too if that might make a difference, anyone have any ideas what it could be or even better how to fix it,
ALLTREC_TURB
Postby DeeCee » Thu Jul 19, 2007 5:02 pm
i had the same problem - here is the solution :)
viewtopic.php?t=56196&highlight=fan
GT Four Adovansu
DeeCee
Postby matt dunn » Thu Jul 19, 2007 9:49 pm
DeeCee wrote:i had the same problem - here is the solution :)
WTF? I read tht and found no answers?
The second last post is still asking.
The answer is you have removed the AC pressure switch which makes the fan run all the time. There would have been a 4 terminal plug on one of the ac pipes heading into the firewall. you need to bridge the two that control the fan. Last one I did was quite a while ago so dont remember the colours.
But bridging two together will stop if.
At a guess they are both blue and something.
Once you have done it run it up to temp and make sure the fan still comes on when needed.
Postby DeeCee » Thu Jul 19, 2007 10:55 pm
oopsie - i got pm'd the answer lol
Twolitre wrote:Hey man I've had a few celicas now and when you removed the aircon you probably unplugged a sensor or two that was attached to the aircon gas pipes near the firewall, if you plug them back in and just tuck them out of the way near the stru tower the fans will run as normal.
If the sensors are permanently attached to the piping then just rip them off, come to think of it if you just bridged the wires from the plugs that go back to the loom that should work too.
Let me know how you get on.
GT Four Adovansu
DeeCee
Postby ALLTREC_TURB » Fri Jul 20, 2007 7:08 pm
sweet as man, thanks for will sort it out when i get it back, went in for a warrent today rear diff mount is buggered to the point where it isnt even really mounting anything:( I have a feeling its going to be expensive but oh well
ALLTREC_TURB
