Aristo 94 , 2jz gte.. help me clarify if this engine is gud?
Postby jdm 102 » Fri Jul 20, 2007 10:53 pm
Hey fellas .. it's time to go Levin Gtz :ph34r:
now to the car that I have my eyes set on , (which I'd like some professional views on as well) . is this..
If anyone has experience with these or can advise , please tell if there is anything in particular I should look out on the Vr-4s ? its a 5 speed tiptronic gearbox, 90,010kms.. theres (what they call) tappet noise (have a report from Option 1 to prove that its tappets only and bottom end is fine) .. it looks sweet and drives pretty decent (compared to the Aristo :P) .. just felt a shudder effect on hard braking which they say is front rotors requiring machining..
Are tappets easy to fix ? and anything in particular that I should look out on these ?
Cheers :)
jdm 102
Postby Dell'Orto » Fri Jul 20, 2007 11:12 pm
All Mitsis get noisy tappets, not normally that early though. The only proper cure is to replace lifters. Dunno what they go for over there, but aftermarket you're still looking at $40 ish each.
The tiptronics are pretty weak too. Cambelt service jobs on those are horrible, the belt itself is about $200 retail.
Postby Mr Revhead » Fri Jul 20, 2007 11:25 pm
its a V6 VR-4
RUN
Postby sergei » Fri Jul 20, 2007 11:30 pm
Stay away from it!
These are notorious for tappet noise, blown turbos, and blown transmission.
Also plenty usual mitsi problems as standard.
Tappet noise would indicate that the odo been messed with or the car has not been serviced regularly.
Cambelt will cost you (so the water pump).
Transmission can let go without any indication.
Postby jdm 102 » Fri Jul 20, 2007 11:33 pm
oh damn...
I really had hopes high on this :( ...
shit.. might have to look at something else now f.f.s
jdm 102
Postby Dell'Orto » Fri Jul 20, 2007 11:47 pm
Wise move, you're really opening yourself up for a massive repair/maintenance bill by buying it.
Postby Mr Revhead » Fri Jul 20, 2007 11:48 pm
and i suspect as its prob not sold new over there itll be even worse than here.....
Postby escortman » Sat Jul 21, 2007 9:35 am
heres one reason why not buy it u can do 1 bank of spark plugs fine otherside real pain in the arse, u have to remove the intake manifold :evil:
4x4 toyota blizzard offroader
escortman
Postby Mr Revhead » Sat Jul 21, 2007 9:41 am
escortman wrote:heres one reason why not buy it u can do 1 bank of spark plugs fine otherside real pain in the ar*e, u have to remove the intake manifold :evil:
i think thats the same for alot FWD V6s!
Postby escortman » Sat Jul 21, 2007 10:18 am
hahaha can u tell i didnt think about it lol
o well still a c**t to work on haahah
escortman
Postby jdm 102 » Sat Jul 21, 2007 10:28 am
ok this particular car needs 100,000kms service soon,
can anyone give me a run down as to how much parts for this cost exactly anyway?
I was suggested that if its in good nic right now, install transmission fluid cooler, oil cooler , regular oil changes (4000kms with good oil) 100 octane only ..
I'm not sure on this 'exact' Galant .. but to be honest, it was decent for the drive and gripped like omfg...
jdm 102
Postby rollaholic » Sat Jul 21, 2007 10:43 am
dont buy it, for any reason, under any circumstances, at any price. they are notoriously problematic, massively expensive to fix... quite possibly the worst car mitsubishi ever made (and thats saying something), especially with a tiptronic.
Postby jdm 102 » Sat Jul 21, 2007 10:49 am
I'm glad I posted here to ask.. because something was telling me hmm in NZ considering all the imports they have, they must have a good idea about that car lol...
and as I just asked a mechanic (well he works on Evos only) , he also said to 'avoid' it , no parts at all.
Cheers fellas
my Levin Gtz is pretty much sold, so I gotta start hunting for a car
Aristo 2jz gte yeh? 8) ... my only concern with that, Auto transmission again :roll: are those ones any reliable or decent to put up with ?
Thanks alot people, really appreciate it.
jdm 102
Postby avinesh » Sat Jul 21, 2007 11:04 am
jdm 102 wrote:I'm glad I posted here to ask.. because something was telling me hmm in NZ considering all the imports they have, they must have a good idea about that car lol...
Cheers fellas
2jzgte is pretty much the strongest engine out of japan an i believe the turbo one will be quicker then the vr4, auto box can shift quick as well after just shimming the accumulators.....i have a soarer 1jzgte which made 220rwkw on dyno yesterday on just basic mods imagine the possibility with a 2jzgte
avinesh
Postby jdm 102 » Sat Jul 21, 2007 4:54 pm
is this gunk??
94, Aristo , 2jz gte .. very clean interior, still needs compliance and no engine oils changed since it got in from Japan.
jdm 102
Postby Dell'Orto » Sat Jul 21, 2007 7:16 pm
Does look pretty filthy under there....really need to take the cam cover off and have a decent look.
Postby Alex B » Sat Jul 21, 2007 7:49 pm
94? Can it even be complied?
Postby jdm 102 » Sat Jul 21, 2007 7:51 pm
yes it can,
the guys said to get a service done once I get it , as they reckon for compliance the workshop really only uses jus adequate quality oil for it..
engine flush and nice oil and should be fine if I keep up the oil changes every 4-5,000kms
what sorta ron rating is the 2jz recommended at? 98 ? 100?
jdm 102
Postby Alex B » Sat Jul 21, 2007 7:54 pm
Silly me thinking of NZ laws :P
Postby nobody » Sat Jul 21, 2007 10:40 pm
Hi
From experience 2 suggestions I would make are:
a) Make sure your insurance cover includes a free replacement windscreen as the Aristo windscreens are suprisingly expensive.
b) Look at getting one of those 2-3 year mechanical warranty type things from the dealer. Many parts on the aristo are made of high quality materials which cost an arm and leg to replace and may need to be shipped from Japan. It's always nicer if the dealer can take care of the cost :)
Other than that they're a great sleeper car and are deceptively quick :D
nobody
