vvt problem
vvt problem
Postby matt9ball » Sat Jul 21, 2007 11:47 pm
ok so if i leave my car idling for 5 min then drive......my vvt works for a few mintues!!!then never goes again..
if i just drive my car as soon as i turn it on vvt wont activate at all even if i drive to dunedin from chch haha
im thinking thermostat as vvt works only when the car is hott????and if you leave idling car heats up more than driving around??
Help much apperciated
matt9ball
Postby matt dunn » Sun Jul 22, 2007 1:19 am
Silvertop or blacktop?
Have you fitted a VVT switch or anything?
how do you know it works or doesn't?
Does it get warm on the temp gauge?
Postby sergei » Sun Jul 22, 2007 2:42 am
if you come to conclusions judging by a vvt light, you are most likely right - thermostat is at fault. Other symptom is that when you drive temperature gauge is at or close to "C".
Postby matt9ball » Sun Jul 22, 2007 2:30 pm
my car has a bad temp sender in it so i cant check running temp.
and silvertop matt
yeah thermostat was all i can think of.........
and yes no vvt switch but there is a vvt light
matt9ball
Postby sergei » Sun Jul 22, 2007 2:35 pm
Use the heater to see if the temp. goes down - if it barely warm while driving on max hot, it is most definitely thermostat problem.
Postby matt dunn » Sun Jul 22, 2007 5:06 pm
Or just fix the temp gauge?
Postby matt9ball » Sun Jul 22, 2007 8:45 pm
lol problem fixed just replaced thermostat
thanks
matt9ball
