GTT
GTT
Postby Pirken » Sat Jul 28, 2007 2:21 pm
Have a LHD Caldina 1999. And i love it !!
Pirken
Postby Adydas » Sat Jul 28, 2007 6:32 pm
Yes and no, as the gtts turbo is built into the exhast manifold for you to fit that youd also have to buy another turbo such as a CT20b to fit onto it.
Then hope the oil drain and dump pipes match up
Adydas
Turbo
Postby Pirken » Sun Jul 29, 2007 12:31 am
I though Caldina Gtt had the CT20B turbo, is it the CT26 on it or something else ? Caldina is not the easiest car to get after marked part to..
Pirken
Postby strx7 » Sun Jul 29, 2007 12:34 am
who knows what the turbo is, but it doesn't have a seperate exhaust housing, so it'll probably fit but you need a new/different turbo to go with it
Postby fivebob » Sun Jul 29, 2007 12:38 am
The Caldina has it's own turbo, which is cast complete with the manifold. It's not a CT20B. It does have the same compressor housing, but the exhaust turbine is a single entry with a large circular wastegate, where the CT20B is twin entry, with an oblong wastegate.
If you wan't to use an aftermarket manifold then any one that is designed for the Gen III 3S-GTE will work(ST205 and late model SW20), but you will also need to buy another turbo as well and add one more stud to the cylinder head.
