GTT howling/siren noise on deceleration
Postby Lats » Sat Jul 28, 2007 10:36 pm
GTT howling/siren noise on deceleration, have no idea what this could be, a tad worried about it.
Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot it becomes the teapot. Now, water can flow or it can crash. Be water my friend.
Lats
Postby Ae92typeX » Sat Jul 28, 2007 11:18 pm
can you locate a general area/direction it is comming from?
Ae92typeX
Postby Lats » Sun Jul 29, 2007 12:25 pm
I jst took for a drive, lots of noises, lack of power, I think my Turbo has gone.
Lats
Postby Boosted_162 » Sun Jul 29, 2007 12:39 pm
GTT's warp their turbo manifolds.. Check this if you havent fixed it before.
Postby 85AW20v » Sun Jul 29, 2007 10:25 pm
Culd also be boost leaking out under pressure through a small split in a boost line. If you can get it to do the same thing while sitting still, you should be able to track it using a length of small plastic hose with one end in your ear and the other in the general area of the leak. Exhaust shops do the same thing to see if they've got any leaks. But be careful when you're getting close as it'll just about deafen you when you find the leak!!
See ya
Simon
85 MR2 20v
85AW20v
