horn fuse keeps blowing
Postby haydo » Sun Jul 29, 2007 2:07 pm
any body know why??
haydo
Postby Alex B » Sun Jul 29, 2007 2:30 pm
I think you will find the hazard lights are also on that fuse, have a look around that area, no new alarm installs etc?? Need a bit more info that "it keeps blowing".
Postby matt dunn » Sun Jul 29, 2007 2:55 pm
When does it blow?
as soon as you replace it, when you turn on the ign, or when you press the horn button?
Postby haydo » Sun Jul 29, 2007 3:48 pm
Sorry it's on my AE101 Trueno.
It happens everytime I go to sound the horn and the fuse blows up. I installed a new steering wheel in few weeks ago and worked fine but then it stopped all of a sudden. So i replaced the fuse and it blew up again and then put my old stock wheel on and it still blows the fuse when I sound the horn.
Any ideas?
haydo
Postby matt dunn » Sun Jul 29, 2007 4:21 pm
dud horn.
Postby haydo » Sun Jul 29, 2007 6:25 pm
so what do i need to replace then?
haydo
Postby Alex B » Sun Jul 29, 2007 6:38 pm
The horn.
Postby haydo » Sun Jul 29, 2007 7:00 pm
it happens in my aftermarket steering wheel too.
haydo
Postby summin » Sun Jul 29, 2007 7:07 pm
matt dunn wrote:dud horn
haydo wrote:so what do i need to replace then?
pyro_sniper2002 wrote:The horn
lol classic :lol:
Nothing beats toyspeed tech advice :D
summin
Postby Zak » Sun Jul 29, 2007 7:07 pm
They mean the actual horn not the button on the wheel.
It's a black circle looking thing by your radiator.
Zak
Postby themaleman » Sun Jul 29, 2007 7:09 pm
the stering wheel is just a 'button' try replacing the horn its self, or maby put a bigger fuse in?
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Alex B » Sun Jul 29, 2007 7:26 pm
themaleman wrote: or maby put a bigger fuse in?
No, thats a bad idea unless you like flames. Factory rated fuse will be fine.
Postby haydo » Sun Jul 29, 2007 7:55 pm
cheers for your help so far guys but can confirm the horn is fine. we just went out and tested it against battery and it works.
it's shorting out somewhere but no idea where.
im stumped :(
any more ideas? lol
haydo
Postby Bling » Sun Jul 29, 2007 7:59 pm
well seeing as the only thing you have changed is the steering wheel, logic dictates to start looking there, take the wheel off and check for loose wires etc
Postby matt dunn » Sun Jul 29, 2007 8:41 pm
There is nothing you can do at the steering wheel to blow the horn fuse.
There is only one wire for the horn circuit and the steering wheel, and if you shoet it to earth all it does is jam the horn on,
it cannot blow the fuse.
Do you realise that 99.9% of cars have two horns, one on each side.
Remove them both and leave them unplugged and try again and see if it blows with no horns.
Matt
Postby WeirdGTi16 » Mon Jul 30, 2007 12:31 am
Youve got a short in your wiring some where :!: If will probably be in the steering wheel power wire. Need to check with test light / multi meter to trace. probably job for auto sparkie if you don't have technical electrical experience :lol:
Never give yourself a haircut after 3 margaritas
WeirdGTi16
Postby matt dunn » Mon Jul 30, 2007 12:48 am
WeirdGTi16 wrote:probably be in the steering wheel power wire.
There is no power from the horn circuit to the steering wheel.
And there is not meant to be.
and if there is no power there you cannot short it out.
The fault cannot be in the steering wheel.
Postby Mr.Phreak » Mon Jul 30, 2007 12:50 am
matt dunn wrote:There is nothing you can do at the steering wheel to blow the horn fuse.
There is only one wire for the horn circuit and the steering wheel, and if you short it to earth all it does is jam the horn on, it cannot blow the fuse.
Matt
But I don't know why anyone would listen to Matt.....it's not like he's an auto electrician or anything :lol:
EDIT: Sneaky bastard got in before me
Mr.Phreak
Postby haydo » Mon Jul 30, 2007 12:16 pm
my horn is fine and as stated above it can't be anything wrong by the steering wheel ... where can i look next?
haydo
Postby slighty_sykotic » Mon Jul 30, 2007 1:47 pm
haydo wrote:my horn is fine and as stated above it can't be anything wrong by the steering wheel ... where can i look next?
For the other horn?
slighty_sykotic
