by sergei » Sun Jul 29, 2007 4:19 pm
No smoke?
if so that is fine, when piston moves down it displaces the air inside the engine (crank case side) when air is pushed out through oil hole it tends to go in a narrow stream, when piston moves up it suck air from outside though oil hole, when air it is sucked it is sucked evenly from all sides, hence you feel it only blowing (same applies for subwoofer port - it feels that it blows air constantly but infact the amount of air inside is constant in longer term).
