turbo oil fittings
turbo oil fittings
Postby bluemaumau » Tue Jul 31, 2007 2:43 pm
am i correct in thinking screw type fittings and braided line on the oil feed and rubber pushlock fittings on the return are the most commonly used turbo lubrication systems?
Postby Lloyd » Tue Jul 31, 2007 2:44 pm
Pretty much. Can use pushlock stuff on the feed if you want
Postby bluemaumau » Tue Jul 31, 2007 2:45 pm
what do most turbos come with? a screw fitting or just a pipe?
Postby Caveman » Tue Jul 31, 2007 5:05 pm
re your pm most factory turbo oil systems are bundy tube and bangos. If you go to GSS you can get bangos/screw fittings coupled onto stainless brainded hose (can do it yourself as well). This should sort oil feed.
On teh return I would use hose/hose clamp between pipe and turbo and a fitting to the sump. You will need to go to GSS or similar to discuss options. Either way its not cheap so take lots of money or get trade discounts :P
AW11 Track Toy
Formerly known as 1998
Caveman
Postby bluemaumau » Tue Jul 31, 2007 6:28 pm
ok cheers mate
Users browsing this forum: No registered users and 22 guests
