4age 16v/20v seals
4age 16v/20v seals
Postby bluemaumau » Thu Aug 02, 2007 7:55 pm
are the rear and front crank seals on all 4ages the same?
also are waterpumps interchangable across all 5 generations
Re: 4age 16v/20v seals
Postby matt dunn » Thu Aug 02, 2007 8:14 pm
bluemaumau wrote:are the rear and front crank seals on all 4ages the same?
1, possibly, except maybe the early bluetop as the craks are different,
2, definatly not, RWD water pump is different to FWD and ST and BT are another 2 differerent one's, so at least 4 versions.
Postby AceSniper » Thu Aug 02, 2007 9:36 pm
2nd that
AceSniper
Postby bluemaumau » Thu Aug 02, 2007 9:55 pm
bugger.
i thort it was just the different piprs coming off the water pumps.
im using a ST block and smallport head. so ill need a ST pump, right?
Postby IH8TEC » Tue Aug 14, 2007 7:15 pm
i used my gze waterpump cause it was pretty new, on my silvertop block
Postby matt dunn » Tue Aug 14, 2007 8:17 pm
the difference between the FWD 16V the ST and the BT water pumps is the shape where the cambelt covers go and how they interfere with the cambelt adjuster,
So i'd say use the water pump to suit the head.
Postby IH8TEC » Tue Aug 14, 2007 8:20 pm
matt dunn wrote:So i'd say use the water pump to suit the head.
that might be why mine fit.
Postby bluemaumau » Tue Aug 14, 2007 8:41 pm
cheers guys
