just made a picture from the msnz spec shet, basicly im not 100% sure on what steel i use on what section of the cage and what braces i should go for so want to just double check!
Is it an over kill? with the angle bar at the back from left corner to right and then the flat bar from left to right? also with the cross bar in the roof? i have to take the 2 arms thru the firewall as i want to remove the air bag system from the vehicle. what about the side impact bars, after reading it my understanding is that these are only needed if u modify the door's/door covers? but personaly i will put them in anyways just for safety. ok so onto the sizes my understanding is the parts i have colour in black are "other members" and are constructed out of 40x2.0mm or 38x2.5mm or 38.1x2.5mm and the white/clear sections are "main rollbar" and are to be constructed out of 45x2.5mm or 50x2.0mm or 38.1x2.5mm correct? what sizes would be best to go for. any help would be greatly apreshiated!
Also were it mounts to each point of the body there must be a patch of 120cm and atleast 3mm thick? and this patch must be fully welded? and the 2 rear arms must be on a 30 degree angel??
thanks!
