removing sound deadening?
Postby Infinite » Sat Aug 04, 2007 1:56 pm
Ok so hows it done? ive done it with a blunt chissile in the past but i dont want the marks on the floor! also have used a rubber hammer but this dont allways work? ive seen some thing about fire extingusher? what spray it and it freezes or somen and then hit it? basicly i dont wana rip up the floor.
Lots
Infinite
Postby Rick » Sat Aug 04, 2007 2:13 pm
I used a piece of wood and made one end like a chisel, make sure you use a hard wood, you will have to reshape the end from time to time. Then use petrol to clean it up.
Postby HachirokuGTV » Sat Aug 04, 2007 2:33 pm
Use a heat gun and Rick's wooden chisel. You can clean up with petrol or you can use wax and grease remover.
HachirokuGTV
Postby slighty_sykotic » Sat Aug 04, 2007 3:59 pm
I'd go other way.
Dry ice all over the floor, then chisel it.
slighty_sykotic
Postby Infinite » Sat Aug 04, 2007 4:05 pm
were to buy dry ice :D
Lots
Infinite
Postby fangsport » Sat Aug 04, 2007 4:16 pm
round the corners offf a wood chisel and chisel away. best done when the car is cool, as warm temperatures softens the deadening.
fangsport
Postby slighty_sykotic » Sat Aug 04, 2007 4:24 pm
Infinite wrote:were to buy dry ice :D
Boc gases.
Take a chilly bin to them
slighty_sykotic
Postby DeeCee » Sat Aug 04, 2007 4:32 pm
Dry ice works well.. chisel off as others say.
You get a very large mess with petrol. Only used petrol for ultra stubborn spots that won't come up
GT Four Adovansu
DeeCee
Postby gasman » Sat Aug 04, 2007 6:30 pm
dryice-->air chisel-->desolve-it or 3m tar remover
"What can possibly go wrong?"
gasman
Postby RedMist » Sat Aug 04, 2007 7:37 pm
HachirokuGTV wrote:Use a heat gun and Rick's wooden chisel. You can clean up with petrol or you can use wax and grease remover.
This is the method I used with the Celica... and it sucked. Its much easier to just knock it off with a chisel. The heat tends to make the material bond to the floor. You'll also find petrol will damage all the plastic gromets.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Infinite » Sat Aug 04, 2007 7:39 pm
i used a paint scraper :D seemd to work a treat have done half the car in 2 hours and has hardly left anymarks at all! just got it on a good bend and taped it with a hammer more dents from droping the hammer :oops:
Lots
Infinite
Postby flygt4 » Sat Aug 04, 2007 7:49 pm
freeze it dont heat it :lol:
flygt4
Postby Mr Revhead » Sat Aug 04, 2007 8:59 pm
degreaser for the remaning sticky bits
Postby Infinite » Sat Aug 04, 2007 9:29 pm
yea have wax and grease at work and acatone
Lots
Infinite
