Spongy Clutch pedal
Spongy Clutch pedal
Postby TRD_ZERO » Sat Aug 04, 2007 8:08 pm
As the title says my clutch pedal all of a sudden got spongy. For example if i rest my foot against it it just goes all soft and all the way to the floor, but if i do fast rapid movements with the pedal i can then feel resistance. Is giving me trouble as i cant get my car into gear or out of gear sometimes.
ITs a ae111 by the way i tried bleading the clutch but no air came out. My second guess would be the seals on the inside of the clutch cylinder. Anyone had this kind of problem before??
TRD_ZERO
Postby Infinite » Sat Aug 04, 2007 8:10 pm
is it losing fluid? could be the inside seals blowing the fluid right past
Lots
Infinite
Postby RS13 » Sat Aug 04, 2007 8:25 pm
Master cylinder seals. Replace either master cylinder, or get a seal kit and rebuild it.
RS13
Postby TRD_ZERO » Sat Aug 04, 2007 8:27 pm
YEah when it started doing that i checked the fluid and it was pretty low. Where do i get one of these seal kits?
TRD_ZERO
Postby B1NZ » Sun Aug 05, 2007 11:55 am
TRD_ZERO wrote:YEah when it started doing that i checked the fluid and it was pretty low. Where do i get one of these seal kits?
Antarctica :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby darkwolf » Sun Aug 05, 2007 1:45 pm
Just replace the cylinder. If the seals are going then the cylinder may not be far off. And it would be b*stard to fix the seals only for the cylinder to shit itself a month after the fact.
As for the parts ask this fella: viewtopic.php?t=44317
darkwolf
Postby hsmidy » Sun Aug 05, 2007 3:02 pm
for the price of a new item ay might as well they dont cost that much and yeah chances are the bore isnt that flash if ya seals have started to go
hsmidy
Postby Ae92typeX » Sun Aug 05, 2007 8:28 pm
BNT should have/be able to get the kit. Of try tradeparts for a replacement master/slave cylinder - they always seem to have the best price for that sort of thing when Im purchasing.
Ae92typeX
