w57 behind a 7mgte..will it handle the jandel?
Postby drtydog » Sun Aug 05, 2007 11:01 pm
done a quick search and so far come up with w55/6/7/8 seem to be about as strong as each other,just differant ratios...correct me if i'm wrong?
anyway local wrecker has a w57 in an old grande,and since my supra is auto i was thinking bout buying it to do a manual conversion down the track. but before i go spending money, will it handle the jandel? the car is stock at the moment, but i do plan to do the usual bolt on mods for a lil more power
drtydog
Postby Quint » Mon Aug 06, 2007 1:20 am
7 and 8s are the same strength, just different ratios, the 55 is a little bit weaker than them. Not sure about the 56, never come across one before!
Quint
Postby kiwilowlux » Mon Aug 06, 2007 7:57 am
my thoughts are that when you get to a decent power level your going to have a problem with clutches.. If you aye easy on the box, power loading should be ok but shock loading (dropping the clutch) will be lethal.
kiwilowlux
Postby Jason T » Mon Aug 06, 2007 9:35 am
MA70 with W58 has handled 5 years+ of daily driving
Im using a full face factory clutch plate with 2100 pound cover plate
Apart form short life span on master cylinders box has never had problems (has had a C's short shifter in place for last 4 years)
Make the clutch plate the weak link
How to retro fit abs to w58
http://forums.mk3supra.co.nz/viewtopic.php?t=340&highlight=w58+abs
Fixing Toyota's since '87
Jason T
Postby supradave » Mon Aug 06, 2007 1:46 pm
Im also using a w58 behind a 7mgt, dragged it a few times down at meremere and its been daily driving for about a year so far without any problems.
ADMIN EDIT: oversized image removed - see forum rules for acceptable image sizes
supradave
Postby drtydog » Tue Aug 07, 2007 11:04 pm
awsum i'll have 2 talk to the wrecker and see how much he wants gotta be better than the old auto box lol
now the box is in a 1g powered grande, will i be able to use the pedel box, clutch master ect ect from that or will i have to try source supra ones? what about driveshafts? will the auto one go in or do i have to get a differant one?
drtydog
Postby MrDori » Tue Aug 07, 2007 11:17 pm
youll need all ma70 manual shafts etc, you;l need a manual bellhousing, that will set you back around 250
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby Jason T » Tue Aug 07, 2007 11:33 pm
You need to find the pedal box master cylinder from a GA70 do it right first time
1st you need flywheel and clutch from any "M" series engine (mine came from a column change crown)
Drive shaft yoke is same 21 spline for auto & 5spd but shaft is longer on manual will need to cut reweld balance
In the link above is the parts list you need
Jason T
