t50 question 22 vs 20 spline
Postby rollaholic » Mon Aug 06, 2007 8:21 am
im looking at a t50 on trademe, only problem being its a 21 spline input shaft. how interchangable are the parts on these boxes? i know i'll be able to use my AE86 bellhousing, can i swap the input shafts over with relative ease too?
cheers.
Postby l1ttle_d3vil » Mon Aug 06, 2007 9:10 am
no, bearings are different sizes IIRC so the housings won't fit together properly. i think all t50s have a 21 spline input shaft anyway, its the output shaft thats either 20 or 22 spline isnt it?
but the biggest difference between 20 and 22 spline (other than the obvious!) is the bearings are slightly larger in a 22 spline.
and you can't use a genuine ae86 bellhousing with a 20 spline t50. ae86s came with 22 spline boxes so if you want to run a 20 spline on an ae86 you need a spacer made up otherwise your gearbox will need a rebuild after about 5000km :x
im pretty sure thats how it is, anyone correct me if i'm wrong :lol:
Postby KinLoud » Mon Aug 06, 2007 10:35 pm
l1ttle_d3vil speaks the truth.
Ken
Ham
021 408 863
Postby rollaholic » Mon Aug 06, 2007 11:54 pm
damn, i figured the price was too cheap to be true :P are the actual gearsets the same? my ae86 shafts and bearings are ok (i think) but synchros are worn, particularly on 2nd. wouldnt be as easy as i had imagined with the bellhousing swap, but could i swap the synchro rings and gears between boxes?
Postby l1ttle_d3vil » Tue Aug 07, 2007 9:15 am
possibly, but compare everything down to every little detail to make sure its the same before swapping it.
...but nothing that the bearings run on / sit on will be swappable as both the ID and OD of the bearings differ. gearboxes are pretty sensitive things!! i've swapped gears around on mine, it fitted up sweet but kept jamming. turned out one of the teeth on a gear had a nick in it, couldn't see anything with the eye but every time it got too that tooth it jammed.
so if you do swap stuff over, make sure it all turns freely with the gearbox assembled before putting it in your car!
Postby Dunny » Tue Aug 07, 2007 10:28 am
I have been told by a very knowledgeable person as far as T50's go that once you crack a T50 open there are about 12 different variations. Such things spacers, needle roller bearings etc etc
Dunny
Postby Mr Revhead » Tue Aug 07, 2007 10:35 am
yes there are many differences.
syncros also differ, syncro hubs, bearings etc etc
Postby Blown5k » Thu Aug 09, 2007 10:47 pm
You can fit a 20 spline outputshaft t50 box behind a 4age t50 bellhousing all you have to do is fit a spacer to locate the housing and make sure the bearings are located correctly against the main housing that way you dont need to change the driveshaft on kps & ke if using the original diff,20&22 spline synchros are the same from what i`ve seen and they share the same synchro sleeves as well.
Supercharged 5k kp60
2005-2006 1301-1600cc Canterbury Car Club race series champion.3rd 0-2500cc.
Blown5k
Postby TRD Man » Fri Aug 10, 2007 9:48 am
Can anbody clarify this bellhousing issue with detail. We're about to do just this (20 spline T50 behind 4AGE) and have not heard of this issue before.
Where is the problem? Is the input shaft on a 20 spline longer than that on a 22 spline?
TRD Man
Postby crispy'86 » Fri Aug 10, 2007 1:20 pm
l1ttle_d3vil wrote:?
I'm using the spacer that comes with the 22 spline gearbox in my 20 spline output T50 without any issies at all, i just used the spacer that matches the A bellhousing and comes off the 22 spline box. , (which is between the gearbox and bellhousing anyway), it's the tapered spacer not the thin ring that is in the 20 spline t50 , Haven't had any issues with changing and it's been like that for round 2 years of constant giving it a hard life.
crispy'86
Postby Blown5k » Fri Aug 10, 2007 1:42 pm
The bellhousings on T series boxs locates the bellhousing you`ll find that the 22 spline output gearbox and therefore bellhousing has a different bearing outside diameter than the smaller 20 spline input bearing therefore you need to make a spacer to centralise the 4a t bellhousing otherwise you`ll have alignment problems its only a few mm but enough to cause problems.
Blown5k
Postby Mr Revhead » Fri Aug 10, 2007 1:50 pm
ah i get it now. cheers.
ill FAQ this
only some of the bearings inside are different. i CBF going through them all now though.
Postby TRD Man » Fri Aug 10, 2007 2:51 pm
Me too! It's an alignment thing - not a length thing. That's great thanks.
TRD Man
Postby l1ttle_d3vil » Fri Aug 10, 2007 4:51 pm
it isn't so much to "centralise" it, but to stop the input shaft moving backwards and forwards between the bellhousing and gearbox, literally. i've got pics of the difference, as you can see the 20 spline bearing sits right "inside" the seat, due to the bearing being smaller than the 22 spline. this in turn makes the bearing sit further down, or "inside" the bellhousing.
Postby TRD Man » Fri Aug 10, 2007 5:03 pm
That's great. cheers.
TRD Man
Postby Blown5k » Sat Aug 11, 2007 10:32 am
l1ttle_d3vil wrote:it isn't so much to "centralise" it, but to stop the input shaft moving backwards and forwards between the bellhousing and gearbox, literally. i've got pics of the difference, as you can see the 20 spline bearing sits right "inside" the seat, due to the bearing being smaller than the 22 spline. this in turn makes the bearing sit further down, or "inside" the bellhousing.
No the bellhousing locates on the outsdie diameter of the input bearing and lower cluster bearing that`s how it is suppose to be if its not then you get the input shaft misaligned,sure you need a spacer to pin the input shaft back against or close to behind against the gearbox casing small bearing boxes use bellview washers whereas big bearing boxs use a shim type spacer.
Blown5k
Postby QikStarlie » Mon Aug 13, 2007 5:07 pm
does anyone know if 5th gear and related parts from a t50, will fit in a t40?
QikStarlie
Postby Blown5k » Mon Aug 13, 2007 8:46 pm
QikStarlie wrote:does anyone know if 5th gear and related parts from a t50, will fit in a t40?
Yes with the correct parts you can turn a t40 into a t50.
Blown5k
Postby QikStarlie » Mon Aug 13, 2007 9:36 pm
awesome, thanks. now to find some broken t50's
QikStarlie
Postby l1ttle_d3vil » Mon Aug 13, 2007 9:42 pm
i got a 20 spline t50 here which would only be good for parts, reason being i'm not sure if everything is there...
pretty sure 99% of it is there though!
