Smallport head question
Postby Maxwedge » Tue Aug 14, 2007 12:56 pm
Can you run a smallport head and inlet manifold using bigport loom, injectors, TPS, throttle body etc etc on a bigport block? And if so would you get a power gain?
Maxwedge
Postby frost » Tue Aug 14, 2007 2:27 pm
you could but its maped differently so youd loose power,
a few things i can think of that would not work..
injectors use different signal
tps use different signal.
Postby rollaholic » Tue Aug 14, 2007 6:52 pm
smallport head has the oil drain valve at the back, with no matching port on the bigport block!
Postby bluemaumau » Tue Aug 14, 2007 7:17 pm
weld return into sump,
does mean sump removal tho
Postby ChaosAD » Tue Aug 14, 2007 7:36 pm
Some people have dropped smallport 4age's into ae82 corollas using the bluetop ecu etc. Have to use bluetop dizzy, injectors etc though.
Not sure if they would gain or lose power over the bluetop.
ChaosAD
Postby RedMist » Tue Aug 14, 2007 8:38 pm
I wouldnt run the smallport injectors with the bigport ECU. You'll wash the bores and cause engine damage. Even with the bigport injectors I would very much doubt you'll get an increase in power. My bet is on a net loss as the ignition and fuel map will be tuned for a different flow charastic.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby rollaholic » Wed Aug 15, 2007 8:22 am
you could just buy my smallport long block and be done with it ;)
viewtopic.php?t=59827
Re: Smallport head question
Postby jondee86 » Thu Aug 16, 2007 8:50 pm
Maxwedge wrote:Can you run a smallport head and inlet manifold using bigport loom, injectors, TPS, throttle body etc etc on a bigport block? And if so would you get a power gain?
No reason why you couldn't swap a smallport head and manifold for
your bigport head and manifold. So long as you are using the bigport
injectors and ECU etc., there should not be any problem.
AFAIK the extra power in the smallport was due to higher com pistons and
an improved injector spray pattern. You won't be using either of these, so
the chances are you will feel little or no change... apart from the loss of
your TVIS.... which might make it feel sluggish off the bottom :-|
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby QikStarlie » Thu Aug 16, 2007 9:19 pm
not likely. port size and intake manifold, have a bigger effect than a bit more compression and spray patterns.
use the smallport ecu or you'l have rich and/or lean patches. no matter what injectors you use with a bigport ecu.
QikStarlie
Max Power vs Godzilla....
Postby jondee86 » Thu Aug 16, 2007 11:18 pm
According to the Club 4AGE spec sheet :
Bigport Max Power 130@6600, Max Torque 15.2@5200
Smallport Max Power 140 @7200, Max Torque 15.0 @6000
So yeah, the smallport has a little more topend power by virtue of the
extra rpm's. If the torque curves are similar, then at 6600 the smallport
is making pretty much exactly the same power as the bigport. So it
doesn't look like the manifold design does much except push the Max
Torque point up the rev range... hm ?
Would this engine be running an O2 sensor ??
Cheers... jondee86
jondee86
Postby QikStarlie » Fri Aug 17, 2007 5:11 pm
yeh thats what the tune generaly follows tho. the torque curve. so diffrent torque curve = diffrent fuel map
QikStarlie
Re: Max Power vs Godzilla....
Postby Mr Revhead » Fri Aug 17, 2007 6:04 pm
jondee86 wrote:According to the Club 4AGE spec sheet :
Cheers... jondee86
however.... find me examples of thsoe that can run those numbers!
