RWD gearbox gurus
RWD gearbox gurus
Postby spencer » Mon Aug 20, 2007 7:45 pm
seen this steel case box behind a 1S-U any ideas was a 5 speed maybe from an aussie corona at a guess? think that bell would still fit a w55 kind of looks like it
ms63 crown
spencer
Postby Mr Revhead » Mon Aug 20, 2007 7:54 pm
Postby Jason T » Mon Aug 20, 2007 7:58 pm
Borg Warner 5spd yes its a POS
Same bell pattern as early celica cast W50
Bellhousing will not fit W55
Fixing Toyota's since '87
Jason T
Postby spencer » Mon Aug 20, 2007 8:00 pm
cheers but na look at the pic all that info is w50, w55 etc, I could be wrong but dont think its anywhere in there
ms63 crown
spencer
Postby spencer » Mon Aug 20, 2007 8:08 pm
cheers came to the conclusion it was a commy box on the piss in the weekend just compared to a w50 bell I have here it seems to have to many bolts to fit to a w50
ms63 crown
spencer
Postby KinLoud » Mon Aug 20, 2007 8:35 pm
Thanks for clarifying that point Jason :)
Ken
Ham
021 408 863
Postby spencer » Tue Aug 21, 2007 10:19 am
you seen one before ken? Im going to grab the bell just to check it out didn't realise there was a w50 to S bell housing
ms63 crown
spencer
Postby the fallen303 » Tue Aug 21, 2007 1:58 pm
you say it's from behind a 1s, possibly out of an old rwd corona? a friend of mine got a w55 from a 1s corona, had w55 stamped on the firewall. hope that helps.
true house of JZ
Stay true to the origin
the fallen303
