turbo oil pressure - video added
Postby Caveman » Fri Aug 24, 2007 2:43 pm
Hi
Does anyone here know the ideal flowrate of oil into a turbo? Or the pressure of oil past the restrictor? Turbo in question is a mistubishi td04.
Planning on running between 10000rpm and 100000rpm so obviously flowrates change across this band, just looking for a guide from any people in the trade.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Bumpy » Fri Aug 24, 2007 5:49 pm
What engine/car you puttin it on?
I'm pretty sure those turbo's dont need a restrictor.
I have a tdo4 from a subby and puttin it on my Starlet, subby engines run about 100psi and the Starlet runs about 60psi, so no need for me to use a restrictor ...
Bumpy
Postby YeMs » Fri Aug 24, 2007 5:53 pm
yeh im pretty sure TD series turbos dont need restrictors, just run engine oil pressure. garret turbos do. but no pressure figures sorry.
Your local Hybrid Elite tech
YeMs
Postby Bumpy » Fri Aug 24, 2007 6:05 pm
YeMs wrote:yeh im pretty sure TD series turbos dont need restrictors, just run engine oil pressure. garret turbos do. but no pressure figures sorry.
Yea, thats right, if I was gonna run a Garret I would need a restricter too.
Bumpy
Postby Caveman » Sat Aug 25, 2007 10:37 am
Running on a turbo jet, we are having problems starting it and I think we are flooding it with oil because its pooling in the turbine housing. Right now we are using a fuel pump to flow the oil (yes this does work) but now I think we should use a ps pump and a variable motor to change pressure.
AW11 Track Toy
Caveman
Postby Akane » Sat Aug 25, 2007 12:37 pm
You checked the basics? ie: turbo oil seals, and the drain pipe is free flowing?
Postby Caveman » Sun Aug 26, 2007 12:44 pm
Akane wrote:You checked the basics? ie: turbo oil seals, and the drain pipe is free flowing?
yea buddy all that stuff is working well. The seals are $&#$% because it smoked however I know it works because we pulled it from a working car. A total guestamate i'd say were flowing around 3-4L/min through the core using the fuel pump.
At first I thought more oil would be better, but after reading up a bit I found this
I made some modifications to to the pipe and remounted it. It stayed on during the second test. The engine spooled up nicely, but then topped out at what seemed like a fairly low speed, and would not self-sustain without the blower. I don't have a tachometer yet, so I am only guessing at the speed. I lowered the oil pressure to the turbo and found that the engine sped up. I then lowered the pressure as far as my crude regulator would allow, and was rewarded with a further increase in speed, but it still would not self-sustain. Obviously the oil pressure was still to high and creating too much drag on the turbo. The oil pump will supply a little over 40 psi. My regulator will cut that down to just below 20 psi, but that is still way to much. Obviously it still needs some work. As a temporary measure, I simply kinked the oil line to the turbo further reducing the flow. This resulted in a dramatic increase in speed, and sure enough it self-sustained. I attempted to explore the performance of the engine, but it was proving too difficult to maintain a constant oil pressure. I will rework the regulator tomorrow and try again.
Taken from http://www.junkyardjet.com/primitive.html
I think part of the reason the td04 dont use a restrictor is they have them on the bango bolt. Ive lost this so am not sure on the size etc.
AW11 Track Toy
Caveman
Postby Akane » Sun Aug 26, 2007 12:56 pm
I'll get back to you when I get my basic gas turbine rating :P
Postby strx7 » Sun Aug 26, 2007 7:40 pm
i know the oil feed banjo bolt on a TD05 has very small holes which act as a restrictor
Postby Bumpy » Mon Aug 27, 2007 8:10 pm
Could it be there is a blockage of some-sort in the return? thus pooling oil in the turbo?
Bumpy
Postby SUBARUCONVERT » Tue Aug 28, 2007 7:16 pm
what size supply hose have u got? the pipe is the restrictor on the subarusits smaller than the 2 holes in the banjo
3ST150
SUBARUCONVERT
Postby Voyeur » Wed Aug 29, 2007 8:53 am
Voyeur
Postby Caveman » Wed Aug 29, 2007 7:45 pm
we have about 1/4 inch going into the turbo with no restrictor. Going to fit restrictor and will post back on performance. Cheers 8)
AW11 Track Toy
Caveman
Postby strx7 » Wed Aug 29, 2007 10:27 pm
if I was a turbo i'd smoke with that feeding me un restircted too
Postby Bumpy » Fri Sep 14, 2007 6:19 pm
Any news?
Bumpy
Postby Bumpy » Fri Sep 14, 2007 6:22 pm
Any news?
Bumpy
Postby Caveman » Sat Sep 15, 2007 9:34 pm
Hey sorry forgot to post up results
It turns out the ideal amount of oil flowing through the turbo is about 2 drops per second, no sh!t. The turbo would bog down and the engine would stall with any more oil.
We took some footage of it running, with a night run with lots of flames flying out the back :lol: Runs really nicely.
We restricted the oil with vice grips on the oil line :lol: Crude but worked.
We are planning another unit with full stainless contruction and a truck turbo 8)
AW11 Track Toy
Caveman
Postby Caveman » Mon Sep 17, 2007 10:49 pm
Uploaded a small video if anyone is interested
http://macsoviet.orcon.net.nz/turbojet1.wmv
Let me know what u think :D
AW11 Track Toy
Caveman
Postby frost » Tue Sep 18, 2007 6:19 pm
thats friggin cool!!! now bolt it on a go kart!
